How much do the OEM 19'' wheels weigh?
Old May 31, 2018 | 12:18 PM
GaaraOTS's Avatar
GaaraOTS
Default How much do the OEM 19'' wheels weigh?
Popular Reply
Jun 4, 2018, 01:39 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
I saw a lot of bad info on the Google search. I just happen to have a full set sitting in the basement right now.
Front wheel pounds
Front wheel KG
Rear wheel pounds
Rear wheel KG
Old May 31, 2018 | 12:21 PM
mahcah's Avatar
mahcah
https://www.google.com/search?q=lexu...hrome&ie=UTF-8
Plenty of results.
Old May 31, 2018 | 04:14 PM
Jwconeil's Avatar
Jwconeil
I have actually wondered if the different styles all weigh the same. The 12+ wheels look lighter.
Old Jun 1, 2018 | 02:16 AM
bnizzle87's Avatar
bnizzle87
The 08-09 wheels weigh in at 23 lbs front and 27 lbs rear. I presume the '12+ wheels weigh a tad more simply because of the added 1/2 inch, but nonetheless, all years are BBS, so can't really go wrong with them. They're not the lightest by any means, but certainly rigid and can take a beating over bad pavements with ease.
Old Jun 4, 2018 | 01:39 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Front wheel pounds
Front wheel KG
Rear wheel pounds
Rear wheel KG
Old Jun 5, 2018 | 01:20 AM
kartoos100's Avatar
kartoos100
That is very helpful. Thanks
Old Jun 5, 2018 | 07:29 PM
Jwconeil's Avatar
Jwconeil
Any idea if the 12+ wheels will fit on a 350without spacers? I know the prior wheels required them.
Old Jun 5, 2018 | 10:02 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
The offsets are almost the same - +45 front and +51 rear. Not sure about caliper clearance.
Old Jun 5, 2018 | 10:37 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Just happen to have one of these laying around too.
2014 Front wheel pounds
2014 Front wheel KG
Pretty sure this wheel is junk, but will check with Wheel Wizard soon to be sure.
Old Jun 6, 2018 | 06:06 AM
mikersoft's Avatar
mikersoft
Interesting... The .5" wider '12-'14 wheel is ~1lb lighter than the '08-'09 wheel.
-Mike
Old Jun 6, 2018 | 09:21 AM
Jwconeil's Avatar
Jwconeil
I figured they would be... they have half the spokes.
Old Jun 6, 2018 | 09:55 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Since we are weighing wheels, I posted this 2½ years ago:
Originally Posted by flowrider
I bought and just received a set of the standard RCF wheels. I will be mounting them on my ISF. I weighed them and:
Front 9" = 25.5 lbs. - Rear 10" = 28.0 lbs.
RCF wheels, but should be apropos here.
Lou
Old Jun 6, 2018 | 01:49 PM
Jwconeil's Avatar
Jwconeil
These sure are heavy for forged wheels. I run the forged F sports and the rears are 22 pounds.
Old Jun 6, 2018 | 09:17 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Pics or it didn't happen.
Old Jun 9, 2018 | 05:47 PM
Jwconeil's Avatar
Jwconeil
I can’t figure out how to post pictures so I guess it didn’t happen.
I have 4 rear fsport wheels. They are 19x9 et 40 and weigh 22 pounds a piece. 275/30/19 square.
