New ISF CAT help
Old Jan 10, 2018 | 09:32 AM
Savixor's Avatar
Savixor
Default New ISF CAT help
Hey guys I'm a new isf owner and my car came with sikky headers and joez exhaust.
I need to add cats on to the joez exhaust after the headers and then move the o2 sensor behind the cat. If any of you have this setup please send me some pictures. I also want recommendation on good cats to pass emission.
Do you guys know how to tell between the sikky v1 and v2. I'm pretty sure mine is the v1 since the old owner probably have it on a while back.
Also looking at weather tech floor liner and from looking around the site I think the lexus is350 rwd will fit perfectly. Thanks for all your help guys.
Old Jan 10, 2018 | 09:42 AM
Leander311's Avatar
Leander311
Welcome to the community!
With cats, you get what you pay for. The metals used therein are extremely precious, and the more expensive offerings use much more of these metals, thus much more effective and long-lasting.
GESi makes the best I'm aware of, with several folks here using them. No CEL's even after gutting the stock pre-cats. There is a bit more exhaust "smell" when starting, but this is expected since these will be located farther from the engine and heat up more slowly as a result. I've some pictures, but it would probably be easier to search for other threads on this. I know I'd reviewed some pics of other installations before going this route myself. Good luck!
Edit: I think this is the lowest pricing I'd found. The 7530 works best with most 3" aftermarket exhaust. The 7830 may fit as well and provides 27% more flow area, though my install was pretty tight with the 7530: http://www.jegs.com/p/Vibrant-Perfor...70442/10002/-1
Old Jan 10, 2018 | 11:17 AM
Rossi's Avatar
Rossi
Sikky V2 headers are wider using 1 7/8 primaries also the design of V1 (green photo) is completely different on the passenger side (left header, white photo).
As far as cats, Magnaflow or Gesi is the most commonly used. Gesi are better but way more expensive. I believe JoeZ exhaust is 2.5 inches in diameter.
https://www.amazon.com/gp/product/B009OLQ1B8/ref=ox_sc_sfl_title_6?ie=UTF8&psc=1&smid=ATVPDKIKX0DER https://www.amazon.com/gp/product/B009OLQ1B8/ref=ox_sc_sfl_title_6?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Attached Thumbnails New ISF CAT help-d88dcb20-dbb4-41f2-aa1c-192f3c0769b2.png   New ISF CAT help-ca7c22c9-243b-4930-ba90-5e13220d9cb1.jpeg
Old Jan 10, 2018 | 12:20 PM
flowrider's Avatar
flowrider
Veteran: Air Force
My old setup used magnaflows.
Cat is this one:
https://www.summitracing.com/parts/mpe-59905
Headers are PPE.
Lou
Old Jan 10, 2018 | 04:11 PM
lexicon72's Avatar
lexicon72
Joe Z is 2.5 inch diameter. PM'd you.
Old Jan 10, 2018 | 06:36 PM
Savixor's Avatar
Savixor
Cat is this one:
Headers are PPE.
Lou
Did you pass the sniffer smog test with this setup?
Old Jan 10, 2018 | 06:41 PM
flowrider's Avatar
flowrider
Veteran: Air Force
It will pass sniffer, but there is no smog testing in the county where I live. But I know of a similarly equipped ISF, up in Phoenix, that did pass the sniffer.
Lou
Old Jan 10, 2018 | 06:45 PM
Savixor's Avatar
Savixor
Lou
I would love to live in your county. BTW thanks for you reply and help. I saw your image on google earlier too.
Now I need to find an exhaust shop around here that can make those nice welds like how you have yours.
Old Jan 10, 2018 | 07:36 PM
Leander311's Avatar
Leander311
Aldo123
Build Threads
Sep 2, 2018 12:34 AM
DRE1615
IS F (2008-2014)
19
Jun 30, 2016 09:23 AM
Nruiz91
IS F (2008-2014)
Aug 5, 2015 08:04 AM
Stuno1
IS F (2008-2014)
Feb 21, 2014 08:33 PM
sickISF
IS F (2008-2014)
Jun 25, 2010 04:25 PM
