Cool unknown features ISF?
Old Dec 21, 2017 | 04:35 PM
  #31
djyoshi626's Avatar
djyoshi626
Originally Posted by Jz39
Re: the windows, one thing I don’t like is that it opens the sunroof as well. On my Infiniti, it only opens the windows. The F is like a wind tunnel anyways—there is no good open window setting to drive in that doesn’t hit you right in the face with a stream of air. Realize this may be nitpicky, but in all honesty this detracts from the nice weather driving experience of the F to me. Best I found is drivers window down, rear drivers window cracked, passenger side windows have to be closed. Sad.
You can have the dealership program it to either open all windows minus the sunroof, or open all windows + sunroof in either tilt or slide. AFAIK, you cannot do it yourself. You will need to fill out the ISF personalized settings form:
http://www.lexus.com/documents/broch...ce/ISF_LPS.pdf
Old Dec 21, 2017 | 05:35 PM
  #32
lobuxracer's Avatar
lobuxracer
Tech Resource
You can do it with Techstream. I did.
Old Dec 21, 2017 | 08:06 PM
  #33
Bigjon3475's Avatar
Bigjon3475
Diagnostic mode:
I don’t remember which button but I believe it’s the info or menu button. If you press it and hold it and cycle the lights on and off four times you enter a diagnostic mode.
Seat belt chime:
1. turn the
key key
to the ON position (press Start 2 times), foot off the brake
2. cycle the odometer with the trip reset button until the ODO is displayed (not trip A or B )
3. turn the ignition to the LOCK (OFF) position
4. unbuckle the driver's seatbelt if it was buckled.
5. turn the
key key
to the ON position (Press Start 2 times). when the dash lights have come on, press and hold the trip reset button and count a slow 12 seconds. (editor's note, hold it more like 30 sec)
6. while still holding the trip reset
button button
, buckle the driver's side seatbelt.
7. the odometer display should read "b ON" or "b OFF". toggle the beep OFF with the trip reset.
8. the process should be completed when you unbuckle or turn the
key key
off
If I got something wrong here I’m sure someone will correct me.
ISFpat
IS F (2008-2014)
42
May 10, 2019 09:56 PM
blackisF08
May 1, 2017 05:43 PM
atxisf
IS F (2008-2014)
Jul 31, 2013 01:32 PM
bam
IS F (2008-2014)
180
Nov 2, 2012 10:29 AM
azidaric
IS F (2008-2014)
Nov 28, 2008 09:43 PM
