Cool unknown features ISF?
Old Dec 19, 2017 | 08:38 AM
mk416's Avatar
mk416
That ISF has a V8.
Old Dec 19, 2017 | 08:54 AM
Vitveet's Avatar
Vitveet
Originally Posted by mk416
That ISF has a V8.
^^^probably THE coolest and most unknown feature of this car, lolol!
V.
Old Dec 19, 2017 | 09:01 AM
mk416's Avatar
mk416
V.
Seriously. All this time I thought I just bought a sporty version of IS250.
Old Dec 19, 2017 | 09:10 AM
jdmSW20's Avatar
jdmSW20
I call it "super f sport"
Old Dec 19, 2017 | 11:53 AM
antnguyen's Avatar
antnguyen
You can hold down the unlock button on your remote to lower your windows.
Old Dec 19, 2017 | 12:01 PM
sleepstate's Avatar
sleepstate
But can you hold down the lock button to roll them back up?
My Volvo did this, well, in every country but the US because its "unsafe" to roll them up automatically
Old Dec 19, 2017 | 12:24 PM
Joker4096's Avatar
Joker4096
They do not roll up with the fob. I'm in the US.
Old Dec 19, 2017 | 02:14 PM
sleepstate's Avatar
sleepstate
Stupid nanny-state
Old Dec 19, 2017 | 02:41 PM
N2LEX2L's Avatar
N2LEX2L
Getting out of my car recently recently and noticed “some red” in the guage cluster as I was exiting... smiled as I realized that the car was letting me know that the battery in the key fob was low.
Old Dec 19, 2017 | 02:42 PM
mk416's Avatar
mk416
Extreme F Sport.
Old Dec 19, 2017 | 06:50 PM
lexicon72's Avatar
lexicon72
You can reprogram the remote to.unlock all the doors on the first press (or when you walk up) instead of having to do it twice (driver 1st, rest 2nd)
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by breakeroh
While in D mode you can paddle shift down to activate D manual mode. It can jump straight from 8th gear to 5th with one paddle shift depending on what speed you were cruising in. When you want to go back to a solid D mode without waiting for the car to automatically switch over you hold the right paddle for a couple seconds and it goes back to the large solid D mode.
Using this method lets you drive in D, keep both hands on the wheel and the shifter in D and not have to move it into M manaul mode. Benefits are it will skip down multiple gears with a single paddle shift as it exits out of D mode and becomes semi manaul, but not fully manaul like when you switch over the gear lever to manaul. Once you takr advanatage of the lower gear to pass you then just hold the upshift paddle for a couple seconds and it switches back to D.
Sort of accurate. When you hold the - paddle switch while in D mode, it invokes S mode which limits the highest gear the transmission will use. It is not the same as M mode. All the 2IS have this feature.
Old Dec 20, 2017 | 03:41 AM
Jz39's Avatar
Jz39
Re: the windows, one thing I don’t like is that it opens the sunroof as well. On my Infiniti, it only opens the windows. The F is like a wind tunnel anyways—there is no good open window setting to drive in that doesn’t hit you right in the face with a stream of air. Realize this may be nitpicky, but in all honesty this detracts from the nice weather driving experience of the F to me. Best I found is drivers window down, rear drivers window cracked, passenger side windows have to be closed. Sad.
Old Dec 20, 2017 | 10:49 PM
isfvss's Avatar
isfvss
Hold the lock button down on the door handle and the windows and sunroof close, works on mine, if you forget .
Old Dec 21, 2017 | 01:42 AM
kartoos100's Avatar
kartoos100
This is only available on the 2010+ IS XX0 models. I have a 2008 IS300 also and it will only shift using the paddles when the gear lever is shifted to S.
