Intermittent BackUp camera..
Old Apr 18, 2017 | 09:14 AM
DCoolBeans's Avatar
DCoolBeans
Default Intermittent BackUp camera..
2010 ISF
So after a few spirited rides, I noticed my back up camera didn't come on in reverse. Its been a week now and its come on only a few times.
Any steps to follow to address this?
thx
Old Apr 18, 2017 | 09:42 AM
mk416's Avatar
mk416
My GS300 had this problem with the intermittent black screen when I shifted into reverse, and the research showed that it's most likely due to the camera going bad.
Old Apr 18, 2017 | 12:19 PM
JPxMODz's Avatar
JPxMODz
Replacement Part Number: 8679053011
You'll probably consider aftermarket once you see the cost
Old Apr 18, 2017 | 02:46 PM
DCoolBeans's Avatar
DCoolBeans
Sheet. Thx guys. Yeah the camera is 600 beans.
Are there any goof aftermarket ones?
Any write ups how to access it? I know its a long shot but wanna see if its the connection
Old Apr 18, 2017 | 03:30 PM
JPxMODz's Avatar
JPxMODz
You could get it here... http://www.lexuspartsdirect.ca/produ...erm=8679053011
With the exchange rate it would still run you $316.45US, but even at that I would definitely be checking on a decent aftermarket. I think Rydeen make some nice cameras at an affordable rate
Old Apr 18, 2017 | 04:57 PM
isfvss's Avatar
isfvss
Just had a look at my Toyota Aurion ( camry) 2011, the camera look identical get a price from Toyota or the wreakers let us know how you go cheers.
Have a go at unplugging it and plugging back in could be a bad connection ??
Old Apr 19, 2017 | 08:13 AM
mk416's Avatar
mk416
Yes.
Remove trunk liner/trim and get access to tail light and license plate light plugs. You should be able to find the socket that powers the camera as well as the video line (not sure what color for the wire). Unplug, clean, re-plug, and try to reproduce the symptom.
If that doesn't work, good chance that you need to replace the camera. It is unlikely the source's fault in this case.
Old Apr 20, 2017 | 08:41 PM
DCoolBeans's Avatar
DCoolBeans
Thx fam! I'll get back to you guys.
any reputable aftermarket camera brand you guys know of?
Old Apr 20, 2017 | 09:56 PM
isfvss's Avatar
isfvss
There must be 1000,s of Camrys at the wreckers go and get a used camera.
Old Apr 23, 2017 | 02:43 AM
2010ISF's Avatar
2010ISF
I had this same problem when I bought my car. Took it into the dealer 3 separate times and they couldn't figure it out so they ended up giving me a new head unit under warranty which somehow fixed the problem
phildogbph
GX - 1st Gen (2003-2009)
Jul 6, 2020 09:17 AM
Rrotz
Jul 17, 2018 04:39 PM
RookieLEX
Jun 29, 2016 02:43 PM
azbullpro
Nov 24, 2014 10:36 AM
GChau87
Feb 5, 2014 07:39 PM
