First time at the track. Really high times, is something wrong?
Old Feb 15, 2017 | 12:39 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
You reset a whole lot more than KCLV when you yank the power on your ECM. ST and LT fuel trims also get zeroed out and start over. Depending on a whole lot of things, this can have a far larger impact than learned knock values.
Old Feb 15, 2017 | 02:07 PM
SikkyMFG's Avatar
SikkyMFG
Former Sponsor
Just curious what do you weight?
Also it looks like you deep staged in that video, do you deep stage every time? That can impact the mph reading.
Old Feb 15, 2017 | 02:12 PM
tas02's Avatar
tas02
And are the results posted raw or corrected numbers?
Old Feb 15, 2017 | 04:06 PM
DCoolBeans's Avatar
DCoolBeans
Originally Posted by I8ABMR
If your plugs are bad change them. My car pulls harder than anything I've seen in three years of ownership after new plugs.
How many miles did you have when you changed plugs? Did they look bad?
Old Feb 15, 2017 | 05:11 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Lexus says every 60k miles. Under track use, they will die quicker.
Old Feb 16, 2017 | 07:08 PM
PTYIS2's Avatar
PTYIS2
155 lbs. I deep staged only that time and it was not on purpose.
Old Feb 16, 2017 | 07:12 PM
PTYIS2's Avatar
PTYIS2
I change them at 8,000 miles, not because of the miles but for the car is six years and i was almost sure pervious owner did not change them. When i took them out they did not look that bad.
Old Feb 16, 2017 | 07:25 PM
PTYIS2's Avatar
PTYIS2
Something that called my attention today while doing some test is that i felt the car faster if when doing shifts in manual i waited a little bit longer when the shift sound beeps instead of doing it as soon as it beeps. in other words.... let it beep a little longer so revs are almost at the exact redline. I think if you do it as soon as you hear the shift beep its too early and you are loosing some RPMs and power. But you have to be careful not to pass the redline or you will loose time.
its just a theory, i need to do some test at the track with timing.
Old Feb 17, 2017 | 04:21 AM
Jz39's Avatar
Jz39
Please don't star the "you should lose some weight" joke...that's as played out as stickers adding horsepower...
Unless he weighs 1000lbs, I'm pretty sure it's not going to cost him a second in the 1/4.
Old Feb 17, 2017 | 06:50 AM
MisterSkiz's Avatar
MisterSkiz
I'm more interested in the IS-F with only 8,500 miles on it! Where did you find it?
Old Feb 17, 2017 | 06:58 AM
SikkyMFG's Avatar
SikkyMFG
Former Sponsor
Interesting. The 60' times are definitely suffering on your car pretty bad, do you have any of other split times from your passes?
This is a valid question, every 100lbs is worth roughly .1 of a second. When attempting to compare two cars this has to be taken in to account, especially when your trying to do this over the internet. Trying to compare to identical cars, one with a 155lbs driver and the other with a 355 driver there is going to be a pretty significant difference.
The next question would be the density altitude during the event.
Old Feb 17, 2017 | 09:33 AM
Jz39's Avatar
Jz39
^^^LOL. Valid for about 0.1s at the most...
Old Feb 17, 2017 | 09:34 AM
PTYIS2's Avatar
PTYIS2
im down in Panama (central america) and its really a small city, for instance to drive from the pacific ocean to the atlantic since it is only 50 miles. Additionally the previous owner used it as a second car using it every other sunday until i bought it in last september with 7,500 miles. Another example that you do low miles in Panama is my other car.... a 06 IS350 that currently have only with 59k miles
Old Feb 17, 2017 | 11:33 AM
SikkyMFG's Avatar
SikkyMFG
Former Sponsor
.1 is a general rule of thumb.
Please keep in mind that "significant" is relative, having come from a background in heads up drag racing I get excited over .1
Damart14
IS F (2008-2014)
47
Aug 27, 2017 06:38 PM
max90034
IS F (2008-2014)
12
Jul 20, 2011 10:33 AM
SilverBull
IS F (2008-2014)
15
Jul 29, 2008 05:01 PM
quikturbo
Jul 20, 2003 05:58 PM
