Improving KCLV and power...
Why not just use water? I do that all the time before a teardown to minimize the carbon clean up. It generates the same clouds of "smoke" seafoam does and it isn't a hydrocarbon that will dilute your oil.
The key to any of these methods is to get the engine really hot. It's the sudden temperature differential that makes the carbon come off.
The other thing you'll likely find with KCLV challenged engines is the deck height isn't optimized so the squish is too great. Squish height is the most critical dimension in a performance engine because it alone determines octane requirements. Get the squish right, and the engine will run ridiculously high compression on crappy fuel. Get it wrong and you'll be scratching your head for years trying to understand why the engine won't run on anything less than the most expensive high octane fuels. Manufacturing tolerance for squish almost invariably puts it in the less than ideal range, and sometimes in the far from good range.
Regarding KCLV challenged engines, I think the 2UR-GSE's are actually extremely consistent. In fact one of our challenges since we began tuning a year ago is that ALL the local cars we tune behave exactly as we expect and ramp KCLV very consistently, so it was only in th course of evaluating datalogs of dozens of ISF's all over the country that we started seeing some variability.
In any case, the extent to which the decarb procedure helped actually really took me by surprise. Previously, I felt that fuel quality/formulation and engine tolerance was the source for some of the variability we saw.
So if anyone is considering doing this, make a note of your KCLV before doing the decarb... reset the ECU after the decarb, and see if it advances to a higher value after running a full tank.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
I will be trying this soon as my KCLV goes up and then after a fill up or two it goes back down.
So I should use sea foam (spray) on the intake manifold (like the pic in this thread) while the car is switched on, spray the bottle until its empty, turn the car off for 5 mins then go for a drive to remove the rest of the Sea foam.
Reset ECU and datalog to see if there's an improvement.
Have I gotten all of this correct?
After doing Seafoam do we need to change plugs or o2 sensors?...So u just ( with car off ) spray into intake behind throttle body ( a good amount) and let sit 10-15 min....then connect air intake back up and reset ECU and run car til it stops smoking?
Water is certainly another good option.
Rafi
Rafi
The other thing to try is run a different brand of gasoline. The only difference between brands is the additive packages (the base fuel is the same in any given market for ALL brands), and I learned from a petrochemical engineer that many of the additive packages are antagonistic, meaning what builds up from one brand gets stripped off by another brand. So I routinely use different brands of gas in my car just to minimize carbon build up. I know it works, I've seen the results. Brand loyalty with gasoline isn't a good thing.
Some clarification on the application would be helpful. I've only used intake cleaner with the car running. This is drawn some interest to me due to having a KCLV challenged car. Spray an entire can into the intake manifold just past the butteryfly making sweeps to drench the entire inside? Or just point and shoot? Does the sea foam expand like great stuff or more runny like wd-40? Let sit for 15 mins. Apologies I have never used this product, I would love to monitor this and report my findings to this thread
Rafi
__________________
Actually, you really want to be doing this with the car running, that way it distributes evenly and doesn't puddle up on the bottom of the intake manifold.
Rafi
Rafi
__________________
