Water Pump DIY
Old Aug 2, 2017 | 09:05 AM
  #31
calteg's Avatar
calteg
Glad it's been helpful to everyone!
Old Aug 3, 2017 | 03:22 PM
  #32
Yodog's Avatar
Yodog
Great DIY thank you.
Old Apr 23, 2018 | 07:13 AM
  #33
liquidtek's Avatar
liquidtek
Bumping this thread because how great the write up is. Just did my water pump this weekend and this was spot on. Need more detailed DIY like this.
Old Apr 24, 2018 | 10:02 PM
  #34
RA112225's Avatar
RA112225
Great to see proper write-ups. This is the type of write-ups you see on ih8mud. Thank you Calteg!
Old Aug 8, 2018 | 12:14 AM
  #35
kimho's Avatar
kimho
Default Incredibly helpful
The water pump showed signs of needing to be replaced. Thanks for this incredibly detailed write-up on how to change it.
Old Aug 20, 2018 | 03:49 PM
  #36
JohnMorgan's Avatar
JohnMorgan
Epic write up, I'll be doing this in the next few months and this was just what I needed.
Old Aug 20, 2018 | 04:11 PM
  #37
calteg's Avatar
calteg
Gimmie dem likes
Old Jul 30, 2020 | 01:47 PM
  #38
nathanhuu's Avatar
nathanhuu
Is it common for the water pump to fail on these cars? Should it be changed when replacing the radiator or just wait until it gives out? Thanks
Old Jul 30, 2020 | 02:51 PM
  #39
Joker4096's Avatar
Joker4096
There was a TSB for the original water pump. Mine leaked on my 08. I replaced it last year after my radiator exploded.
Old Jul 30, 2020 | 03:28 PM
  #40
Scott610's Avatar
Scott610
Good thing I’m doing mines since Rrracing has already removed the whole engine out the car for the rebuild on my motor. Car is old things break I might as well while it’s out .
Old Jul 30, 2020 | 10:25 PM
  #41
nathanhuu's Avatar
nathanhuu
I’ve read the leak occurs mostly in 08’ before part numbers was changed in 2010. Was wondering has any 2010+ was affected aside from wear/tear due to high mileage.
Old Jul 31, 2020 | 07:47 AM
  #42
kzlflash's Avatar
kzlflash
Interesting, what are they doing to the motor, or just a refresh for longevity?
Old Jul 31, 2020 | 08:01 AM
  #43
lobuxracer's Avatar
lobuxracer
Tech Resource
It hasn't been a topic of discussion on this forum since the original units had their problems, mine included. Coolant pumps are not a forever item, they do wear out for sure. I plan to replace mine when I do the major maintenance at 180k miles. It would have been done pre-Covid, but I'm still at 177k right now.
Old Aug 1, 2020 | 03:28 PM
  #44
Joe Z's Avatar
Joe Z
Lightbulb
At this point it's safer to replace under wear & tear protocols.
If your lucky the WP will alert you when it's time before some type of full failure..
In my case my Radiator Top Seal had a premature failure few years back. At the time I only did that part.
Last summer I did some maintenance items like WP, Thermo, Tensioner & Drivebelt.
Yes my WP had a stream of dry fluid showing its age and time to change.
Due to Covid my IS F has been stuck at 179k since March, I'm usually good for 1,600 miles a month.
Joe Z
Old Sep 2, 2020 | 08:06 PM
  #45
kzlflash's Avatar
kzlflash
So I ordered a new waterpump from Rock Auto, AISIN WPT187. The box is labeled with OEM part # 16100-39506, which is the updated part according to Lexus, but the actual waterpump has 2A on the casting instead of 3A, which according to the OP is the "defective" version. Does anyone know if the 2A cast is an actual telling sign that I received the defective version?
