Water Pump DIY
08-20-16, 07:49 AM
12-21-16, 08:06 AM
My water pump is leaking at 105,000km thank you for the detailed DIY I think I am going to do it myself. The dealership quoted $700 to get it done...
12-21-16, 08:22 AM
We just had ours replaced, luckily under the Lexus extended warranty. Documents show the cost (but covered by Lexus) was $461.00 Great write-up for those who want to save a good chunk of change by DIY.
12-21-16, 11:16 AM
12-21-16, 02:46 PM
THis is one of the best write-ups I've seen on any forum. OP, thank you! I'm sure I will need this in the future.
And yesh, this should be a sticky.
12-22-16, 04:52 AM
Wonderful write up! Thank you very much!
12-22-16, 03:57 PM
May I ask how much for the water pump ? Did you order online or from lexus dealer ?
12-31-16, 04:19 PM
Thanks for the write-up! Did mine tonight. Pretty easy. May want to change that 7/32 Allen wrench to an 8mm Allen wrench. Might be the reason why yours started to strip, other than needing money for college or maybe she's a single mother...Hey I don't judge lol. But seriously great write-up. I did find that if I positioned the mixing valve just right it will rest on the valve cover it is under.
02-28-17, 06:20 AM
Quote:
Originally Posted by
ISF350
I used Aisin WPT187 from here:
http://www.rockauto.com/en/catalog/l...ater+pump,2208
currently $88.79 + shipping
02-28-17, 06:33 AM
I used the same water pump! Great write up! It took about 2.5 hours going slow and drinking a few beers in between!
02-28-17, 02:46 PM
Great instruction. Where did you order the oem water pump ? Do you have a suggestion online place that cost less than dealer ?
02-28-17, 03:39 PM
Aisin seems to be highly recommended and about 1/2 the price of Lexus OEM.
03-01-17, 06:43 PM
Nice DIY waterpump write up :)
I don't know If I'll ever do it myself. But this is a darn good step by step instruction. You sir deserve an A+ hahaha
03-02-17, 05:02 AM
FYI you don't have to actually remove the tensioner pulley
Thanks for the DIY. 09 with 104k miles on the original pump. I used the AISIN pump as well. I believe it's the same as OEM
07-30-17, 06:25 PM
Excellent write up. Did the swap this weekend. Took about 4hrs total with a lunch break in between. I went with Aisin WPT187.
