ISF BBS wheels help
i know my wheels weigh 23 and 27 and some odd change, unless I am remembering incorrectly.
I know because I weighed mine, just can’t remember the exact decimal point measurement and there are super emotional men on this forum who freak out if you say something that is wrong. I learned to preface my facts with I think to avoid temper tantrums.
Seems to be all forums i've visited, not just this one...but this one seems to be the most relaxed one. We will argue regardless..expample...why did i buy BBS LMs to put on my 2012 when i have the OEM wheels in the garage, they weigh similar but folks will argue down to the ounce. Even then, we'll probably debate about the quality of the scale and when it was calibrated..and by who.
. I like LMs, and if you track a spare set of wheels is a needed investment.
Just asking the experts.
I am putting these BBS ISF wheels on my ISC. Would 225/35 and 255/35 be the right tire sizes without rubbing? OEM on the ISC is 225/40/18 front and 255/40/18 rear. Stock suspension. Currently the wheels have 225/40 front and 275/35 rear.
Edit: They won't fit on the 350 without spacers, start with this thread (if needed): https://www.clublexus.com/forums/is-...-on-is350.html
^^^^That thread is talking about the original 8" front wheels. The wheels Ryan will be using is the later 8½" wide wheel. Offset is the same @ +45mm. So, all things being equal, the spokes will be out ¼" further from the calipers. The wheels should clear the IS350 calipers fine. Ryan's tire choice looks fine as it maintains the stock ISX50 stagger and tire OD.
Lou
Lou
Lou
Lou
i will pick up and install tomorrow
as always your expert opinion welcome
Lou
Lou
