Need Some Quick Help on RB XT910 Pad installation
Old Jan 26, 2016 | 10:58 AM
Defratos's Avatar
Defratos
Exclamation Need Some Quick Help on RB XT910 Pad installation
So I'm in the process of installing Figs 2-piece rotors along side the Racing Brake XT910 Pads.
Just noticed the pads have a notch on one side. Is this supposed to indicate up or down? and if so what is the correct way of installing this pad??
Old Jan 26, 2016 | 11:14 AM
Defratos's Avatar
Defratos
Well going by this thread: http://figsengineering.blogspot.com/...akes-with.html It seems like on the outside pad the notch stays on top and on the inside pads the notch is located at the bottom. (They used Hawk pads but still same notch location concept should apply).
If anyone believes otherwise let me know.
Old Jan 26, 2016 | 11:54 AM
MisterSkiz's Avatar
MisterSkiz
Its for electronic wear indicators, which our car does not have. They do not indicate up or down. The pad can only go in one way.
Another tip if you are having issues getting guide pins out, is to sand them down with some sand paper to get the oxidation off of them.
Old Jan 26, 2016 | 11:58 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Those pads are a universal pad made for Brembo calipers and fit certain MB models that have a brake wear sensor that utilizes the notch. It has no meaning or use in an ISF. My Frodo DS2500s also have the notch.
Brakes made specifically for the ISF do not have the notch.
Lou
Old Jan 26, 2016 | 12:10 PM
Defratos's Avatar
Defratos
thanks for the feedback, yeah just realized they can only go in one way as all of them are notched in the same place.
Old Jan 26, 2016 | 01:34 PM
SoulFreak's Avatar
SoulFreak
Post pics of those two piece rotors! Congrats! I know they're a pretty penny! Please review the rotors and pads as you gain mileage! I look forward to these one day...
Old Jan 30, 2016 | 08:55 AM
FIGS's Avatar
FIGS
The Maker
Sorry I missed this but glad you got it sorted out. As mentioned this is the FSMI backing plate that is common with many MB applications so it has the side mounted wear sensor. Just let me know how everything works out after bed in.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Slash300zx
RC F (2015-present)
20
Sep 1, 2024 10:28 AM
soupdawg
Automotive Care & Detailing
Nov 27, 2009 02:25 PM
Rock-a-Lex
Suspension and Brakes
Jun 8, 2007 05:21 AM
933005spd
Jun 4, 2001 06:55 AM
