CALIFORNIA SMOG TEST with just a OBD port test?
Old 10-11-15, 09:02 AM
idoke1
idoke1's Avatar
Exclamation CALIFORNIA SMOG TEST with just a OBD port test?
Recently, I went with my buddy to get his car smogged. He has a 2003 mitsubishi lancer. All the shop did was plug in their obd scanner and did a quick visual test. In less then 10 mins, we were on our way. No probe into the tailpipe. I looked at the smog report and there seems to be no "emissions test" I know CA did some changes and i heard about the new obd scan check but I never experienced it until yesterday. Has it come now that vehicles years 2000 and up ECUs can read emissions test such as HC,NO, and CO reading through the new CA smog check OBD tool? Need more info on this.
Old 10-11-15, 10:11 AM
lolfunxion
lolfunxion's Avatar
You just answered your own question.
It's been known CA doesn't go into the tailpipe anymore. Google is also your friend.
Maybe ask a more specific question?
Old 10-11-15, 11:12 AM
idoke1
idoke1's Avatar
Wink
I've google the info and still did not find the answer. Does our ecu report Hc,NO, and CO readings through the CA smog test OBD Scan?
Old 10-11-15, 11:51 AM
I8ABMR
I8ABMR's Avatar
sounds like AZ smog. I was in and out in 6 minutes and even got a reciept. I was blown away and all this with a Joe Z exhaust and a AOS. LOVE IT !
Old 10-11-15, 11:54 AM
Miqueaseli
Miqueaseli's Avatar
I went in to smog opened hood connected obd2 . And vamonos I have secondary cats removed straight pipes. Passed 40 bucks and on my way .
Old 10-12-15, 02:29 PM
SoCalISF
SoCalISF's Avatar
It's all about the money!! Environment? Yeah right! Revenue? Absolutely!
Old 10-12-15, 02:31 PM
Fsport2UR
Fsport2UR's Avatar
2000 model year and newer vehicles (except for vehicles 14,000 GVWR or greater) no longer require the tailpipe portion of the smog inspection.
http://www.smogtips.com/new-smog-law-ab-2289.cfm
Old 10-13-15, 09:24 PM
semnosNSX
semnosNSX's Avatar
I'm curious what the new equipment that they are using to read the ECU is looking for. Is it simply looking for the same items that would trigger the check engine light? Or does it do some sort of "deep dive" into the ECU looking for data that that nobody would ever have access to?
If the equipment is simply looking for the same items that trigger the check engine light, then this may be a good thing for ISF owners who have I/H/E being that there are no ECU tuning capabilities for our car. Theoretically, if SIM's were used correctly for header installs, and no check engine lights were on, the ECU should just tell the new equipment that everything is okay (despite haveing no cats, hi-flow cats, etc).
Old 10-13-15, 10:33 PM
idoke1
idoke1's Avatar
Exactly what I am thinking. I am very curious to see if the obd port used for smog can do.
Old 10-14-15, 09:50 PM
VMRWheels
Former Sponsor
VMRWheels's Avatar
While I don't personally drive an IS-F, my car has CAI, Headers and exhaust. All i did was roll up and show them all my CARB stickers.
Plugged in that OBD reader, ran the test and I was on my way
Old 10-14-15, 10:13 PM
KahnBB6
KahnBB6's Avatar
Received 1,223 Likes on 858 Posts
semnosNSX, your theory is actually much closer to what could be the truth. While the dyno roller isn't needed for 2000-2001 and up cars the equipment may actually be able to detect reflashes by verifying the checksums in the ECU. Every time you flash any ECU this is the trace it leaves and it's a tipoff that the programming may have been changed.
So far no one has complained about not passing a smog test in any car with an ECU reflash but the technology to detect this is available. Remains to be seen what the ARB will do in that regard.
Old 10-14-15, 10:41 PM
semnosNSX
semnosNSX's Avatar
I hope you are correct. Let's keep our fingers crossed that the new equipment just looks at surface level data and nothing more. I actually have to get my car smogged by next month, but I only have an exhaust so I'm not too worried. However, I am seriously considering PPE headers, but haven't pulled the trigger yet due to our lovely smog laws here in Cali.
Old 10-19-15, 01:31 AM
KahnBB6
KahnBB6's Avatar
^^ I hope so as well. Also, I'm keeping an eye on the way the DMCA is being leveraged by John Deere & GM et al as a copyright protection measure for OEM ECUs. That's still being debated in Washington. Thankfully that's not yet an issue.
IS300H744
08-20-13 10:59 PM
2jzinsider
SC- 1st Gen (1992-2000)
02-07-13 06:56 PM
cilverlex
Performance
08-19-08 06:01 PM
Yeah!
IS F (2008-2014)
05-10-07 12:13 PM
bob2200
Maintenance
07-07-06 10:10 PM
Quick Reply: CALIFORNIA SMOG TEST with just a OBD port test?
