CEL Light is on - Help!
Old Aug 23, 2015 | 06:23 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
When I was building engines, I would cut the plugs apart to see how they were doing. Just slice off the crimp ring around the top and carefully pull the insulator out to get the plug to reveal all the secrets hiding under the metal shell. The one thing you never want to see is aluminum "whiskers" on the porcelain. It means the tops of the pistons are eroding and very bad things will be happening shortly.
Old Aug 24, 2015 | 04:05 AM
KOKISF's Avatar
KOKISF
If you ar spraying over 150 shot some sord of high octane fuel need to be used ,like 100 octane unleaded mixed w 93 so you dont get pre ignition or detonation and yes two step colder plugs,
Old Aug 28, 2015 | 05:52 PM
Bakewalk's Avatar
Bakewalk
Just an update. Lexus checked cylinder #8 and found nothing wrong what so ever with the plug or the coil. They took the plug and moved it to #4 and took the coil and moved it to #2. We will see if there are any new problems that come up. I drove her pretty hard coming home and she felt very sharp, very strong!
Old Aug 28, 2015 | 08:51 PM
KOKISF's Avatar
KOKISF
Cool beans ! One step colder plugs and some 100oct mix w 93 , when spraying!
jakob27990
Jan 15, 2017 02:31 PM
rickmoore
Dec 2, 2013 10:07 AM
mikegbuff
Jan 25, 2013 03:46 PM
wqqclhtt
Jul 1, 2009 07:43 PM
incharlest
Jan 19, 2009 06:38 PM
