Front Brake issue
Old Jul 1, 2015 | 10:02 PM
RRRacing's Avatar
RRRacing
Sponsor
Originally Posted by Vervish
I would pull out the pads, clean the the backing plates and add a little lube (to the backing plate).
Very easy to do with basic hand tools..
I second that. If squealing bothers you, you can get special brake grease and spread between the pad and the backing plate. Also check to make sure the anti-rattle clips are properly installed.
The Hawk pads we sell come with a vile of grease in each box.
-Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old Jul 2, 2015 | 10:37 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
This is what Brembo uses, and what Lexus repackages from Brembo.
https://www.clublexus.com/forums/att...p-pbc-engl.pdf
Old Jul 2, 2015 | 10:53 AM
flowrider's Avatar
flowrider
Veteran: Air Force
I used this stuff:
Amazon.com: Permatex 85188 Ultra Disc Brake Caliper Lube, 0.5 oz.: Automotive Amazon.com: Permatex 85188 Ultra Disc Brake Caliper Lube, 0.5 oz.: Automotive
Worked for me
Lou
Old Jul 2, 2015 | 10:59 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Also, FWIW, my track pads get no love at all. I just stuff them in the calipers, bed, and drive. No shims, no lube, just pistons on backing plates.
Old Jul 2, 2015 | 02:48 PM
mikersoft's Avatar
mikersoft
I have a similar (intermittent) problem with my Project Mu NS400 pads. I used Permatex copper anti-seize between the pads & shims, and bedded them immediately after installation.
Initially, they'd squeal for a couple seconds as I pressed the brake pedal, but then got quiet. That only lasted a day or two, then they were pretty much silent for a month or so. Now, I'm getting the squeal again that goes away as the pedal is pressed further or if I lift my foot & brake again. This is very intermittent & so far I'm unable to correlate it with any outside factors such as cold brakes, outdoor temps, humidity, etc.. It's completely random.
Perhaps I didn't use enough Permatex? Or maybe I should clean 'em up & use a different lube (like the Brembo stuff)?
-Mike
Old Jul 2, 2015 | 03:08 PM
ISFPOWER's Avatar
ISFPOWER
i bought that brembo brand grease through my local lexus dealer. they didnt even know what i was talking about i had a part number ready and indeed, they found some in stock. very expensive grease but it took away ALL sounds from my brakes and held up for over 2 years now with zero noise in every weather and temperature. I believe the grease is like copper anti seize.
Old Jul 2, 2015 | 03:52 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by ISFPOWER
...I believe the grease is like copper anti seize.
It's similar but it is electrically non-conductive and does not interfere with ABS or wheel speed sensors. It's polybutylcuprysil for what that is worth. I spent a couple of hours digging into this, and found this PBC compound is what Brembo and other OEMs specify when they want quiet braking without concerns about wheel speed data. Otherwise, I'd just buy the Permatex stuff Lou linked, because I am just about sure the only difference is conductivity.
Old Jul 2, 2015 | 04:22 PM
ISFPOWER's Avatar
ISFPOWER
Good Info Lance. that permatex brand is what most of my avid track friends use on their pad changes.
for those who do go with the brembo brand from dealer, one packet BARELY will cover all 4, so use enough and sparingly or just buy 2 (will be over 60 bucks though)
Old Jul 2, 2015 | 08:37 PM
clarionguy's Avatar
clarionguy
I just did full front Rotors and Pads.
The other times I used the Brembo / Toyota part number grease.
This time on the backing plate and shims I used heavily: (make sure all existing grease and dirt is cleaned off the shims / parts
Amazon.com: Permatex 24125 Ceramic Extreme Brake Parts Lubricant, 8 oz.: Automotive Amazon.com: Permatex 24125 Ceramic Extreme Brake Parts Lubricant, 8 oz.: Automotive
All Pins and other contact points I used the 3M Silicone Paste
Amazon.com: 3M 08946 Clear Silicone Paste - 8 oz.: Automotive Amazon.com: 3M 08946 Clear Silicone Paste - 8 oz.: Automotive
Gone probably 2-3k with zero noise
Old Jul 2, 2015 | 09:32 PM
Quadrphnia's Avatar
Quadrphnia
Originally Posted by Rickna
I had some squeal as I would come to a stop with OEM pads & rotors. I replaced them with Centric rotors & Stop Tech pads-problem solved.
QFT!! I snuck off to an industrial park and bedded mine in tonight! Hehe!
Old Jul 3, 2015 | 06:46 AM
VuSpec's Avatar
VuSpec
I have the same problem after I wash the car. Just make sure you have grease on the backing plate.
esaicorral
Suspension and Brakes
Apr 18, 2017 02:18 PM
mrjazz
May 24, 2015 03:30 PM
Gregoose
May 4, 2015 04:11 AM
magius231
Aug 25, 2010 10:55 AM
Farino81
Jun 26, 2009 06:13 PM
