White 2011 ISF servicing at Lexus of edison
Old 06-19-15, 05:50 AM
Jmt1011
Jmt1011's Avatar
Default White 2011 ISF servicing at Lexus of edison
Is this a members car here? I dropped mine off for service and saw it sitting in the lot. It looks great and I wanted to see what kind of drop and front splitter you have!
Old 06-19-15, 07:47 AM
Vervish
Vervish's Avatar
That's mine..thanks!
Lexon carbon fiber rep and swift springs (and 15mm HR spacers). I was getting radiator recall and oil change.
Old 06-19-15, 07:51 AM
Jmt1011
Jmt1011's Avatar
Very well done! Did you need to roll the fenders with the drop? I am running the same 245/275 setup.
Old 06-19-15, 08:21 AM
Vervish
Vervish's Avatar
No fender mods at all..i get very, very slight rubbing in passenger front when turning sharply to the left while reversing. All other situations - no rubbing at all.
Old 06-19-15, 10:22 AM
Rossi
Rossi's Avatar
I run the same setup ..... Lowered, spacers, wide tires.
I had the same issue, easily fixable.
Check the little openings in your inner liner.
They are only on the passenger side and sometimes they crack and stick out.
I had to cut just a little piece which was sticking out just to reshape it to its
original shape ....... No rubbing .... zero. It was a good day
Old 06-19-15, 12:06 PM
Vervish
Vervish's Avatar
Thanks for that..i will check it out.
Old 06-19-15, 02:17 PM
I8ABMR
I8ABMR's Avatar
I am tempted with the springs and spacers route. The car looks so good and still looks like an ISF.
Old 06-19-15, 02:24 PM
Jmt1011
Jmt1011's Avatar
After seeing vervish's car, I am def going with the drop and spacers. Car is aggressive yet maintains a classy look.
Old 06-19-15, 02:46 PM
Vervish
Vervish's Avatar
I love the look - should have come like that from the factory IMO. Only downside of the lower offset is that everything gets sprayed on the body of the car..especially wheel shine.
Vervish
Vervish's Avatar
Btw..i am only running the front springs, rear is stock. I like the slightly raked look..
no6thgear
Lexus Vehicles Classifieds
24
05-30-17 12:36 PM
bojarka24
Maintenance
12-23-15 02:48 PM
dwin888
IS F (2008-2014)
22
12-03-12 09:50 PM
Quick Reply: White 2011 ISF servicing at Lexus of edison
