alignment experts
Old Sep 3, 2014 | 01:19 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
I doubt Gran Turismo has the capability. I'd say you'll need either a Lexus or Toyota focused indie or a dealer for the yaw reset. It has to be done with Techstream.
Old Sep 12, 2014 | 03:30 PM
alnug's Avatar
alnug
hi,
While you'd probably want to try to even the numbers as best you can with adjusting the subframe etc. realistically if that's not possible the best bet you have is at least trying to even out the numbers that you can work with.
While front camber being out will affect the steering it's the uneven rear toe that i'll be more concerned about. I'm sure they left it because the computer says they are within spec, but if you have a proper feel for the car it'll make a difference. changing the toe in the rear will affect Toe in front, so if you're trying to sort this. I'd start with getting the rear toe matched evenly e.g 0.10 and 0.10 and then see how that affects front toe and adjust that. Once that's done drive the car for 100 miles or so so the tyres get a chance to bed into the new setting and reassess if you want to go further.
Don't forget they could make it worse by getting them to mess with the subframe.
etct3189
RX - 3rd Gen (2010-2015)
May 20, 2018 06:57 AM
gs350on22s
Mar 24, 2009 05:48 PM
SPEED&ECO.
Jan 28, 2007 02:40 PM
One HoT
Nov 7, 2002 02:20 AM
