Anyone have this problem? (low coolant, overheating)
Old Jan 14, 2014 | 11:58 AM
MisterSkiz's Avatar
MisterSkiz
Hmmm...could this be the next issue with the car after the 08 Waterpump fiasco?
Old Jan 14, 2014 | 12:17 PM
jkeifer3's Avatar
jkeifer3
Originally Posted by HellaInc
UPDATE: I did fill up the coolant to full until I was able to bring it in to the dealership. Service advisor called today and said they found where the leak was and it was leaking into the intake manifold valley which is why I couldn't spot any residue around when I was looking. Pretty suprised this happened on a 2012. I'm at 40k on the clock right now.
The smell of hot antifreeze is unmistakable, should have been horrendous and would have been the first sign of something starting to leak.
Glad you got it fixed before disaster struck.
Old Jan 15, 2014 | 01:26 AM
crazee201's Avatar
crazee201
Waterpump leak is no big deal with the F to LEXUS. It's a common issue and majority of the F owners have gone through it and had it replaced. LEXUS never bothered to put out a TSIB or any service bulletins regarding about this faulty issue.
Old Jan 15, 2014 | 09:54 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
There's no reason to. TSIBs are for procedures not found in the FSM. Replacing the water pump is definitely in the FSM, and not all water pumps failed under warranty - or at least not enough to make Lexus worried about replacing a whole lot of 2UR-GSEs. The entire UR series of engines use this same pump, so many models were affected. They just updated the parts and replaced as owners noticed the failures. Basically, Aisin just screwed up on these.
The 2GR-FSE cam sprocket replacement was a TSIB because the procedure was a bit buried in the FSM, and they wanted to track it carefully. The fact they went through five iterations of cam sprocket designs also indicates there was more to the problem than meets the eye.
mvierneza
Oct 19, 2018 08:47 PM
Tantrix
Jan 20, 2017 05:41 PM
ska0057
Dec 2, 2008 05:25 AM
turbohye
Feb 7, 2008 10:28 PM
FireCode
Feb 9, 2004 09:35 AM
