Track Recipe:
Old Apr 25, 2013 | 12:18 PM
ISFFF's Avatar
ISFFF
Default Track Recipe:
I haven’t been much lately on this form. I need to report back on my track experience.
I have done the following simple upgrades that make a hell of a difference on track:
o Enkei PF-01s, 18 x 9.5, +45 offset with Toyo R888 285/30/18s on all four corners
o FIGS 2-PIECE BRAKE ROTORS with Carbotech XP12 fronts and XP10 rears.
o Dot 5.1 brake Oil
I have been to Dubai Autodrome track day with serious race prepped cars and I never felt out of my place! It only took a couple of laps to earn the respect of other drivers. Usually what happens those guys will overtake you at any corner at any speed without a slight hesitation! I had many of those drivers approaching me after the first session admiring the cornering speed of my F. The very same ones who were skeptical about seeing a Lexus on a racetrack! They were like what the hell is a Lexus doing on a racetrack! Well… now they now.
I’m really very satisfied with the F in general and with the upgrade I did to it. I can’t help thinking that this car will make a serious track toy, or even racecar if I only can manage to reduce some weight. Maybe one day in the feature, when the warranty is over, I’ll convert it to a racecar.
Old Apr 25, 2013 | 02:29 PM
Bigcloud's Avatar
Bigcloud
Thanks for sharing! Any pics?
Old Apr 26, 2013 | 04:24 AM
darbs242's Avatar
darbs242
i assume your on a factory suspension? how close are you to rubbing with the 888's? they run fat compared to other 285's
Old Apr 26, 2013 | 05:53 AM
ISFFF's Avatar
ISFFF
I am on factory suspesnion. The 285 are damn close to the front suspension. They bearly clear it with about 2 mm of gap between the. No rubbing though.
Old Apr 27, 2013 | 04:27 PM
ISFFF's Avatar
ISFFF
Here are some pictures from the track day
Attached Thumbnails Track Recipe:-img_3089-1.jpeg   Track Recipe:-img_3093.jpeg   Track Recipe:-img_3094.jpeg   Track Recipe:-img_3095.jpeg   Track Recipe:-img_3097.jpeg
Old Apr 27, 2013 | 07:09 PM
emperors6's Avatar
emperors6
How did you follow the rotor & brake pad bedding procedures? Did you install right before going out for laps?
Old Apr 27, 2013 | 07:22 PM
ISFFF's Avatar
ISFFF
No rubbing.
I did the bedding at home a day earlier and just drove to the track
Old Apr 27, 2013 | 09:03 PM
FIGS's Avatar
FIGS
The Maker
Excellent report. So glad it resolved the braking issues you were seeing previously. You live in one hot desert so I am glad you are happy. Those pads kinda throw you through the windshield
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Apr 28, 2013 | 08:45 AM
ERDoc74's Avatar
ERDoc74
good to hear you are enjoying your F at the track and getting respect from fellow drivers!
Old Apr 28, 2013 | 10:37 AM
Defratos's Avatar
Defratos
2 piece rotors make a world of a difference.
You're lucky you're in Dubai, you guys have some nice tracks to race in.
Old Apr 29, 2013 | 06:47 PM
CarbonISF's Avatar
CarbonISF
Did you need to modify the fenders for that tire fitment? I'd be interested in trying that out.
Old Apr 29, 2013 | 07:35 PM
ISFFF's Avatar
ISFFF
No, nothing at all. The tires fit just fine without rolling the fenders.
Old Apr 29, 2013 | 07:50 PM
1sWt2GS's Avatar
1sWt2GS
if you do constant tracking you should look into sway bars.
Old Apr 30, 2013 | 12:57 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
You'd be way ahead to just get better suited springs. Stiff sways are a bandaid for soft spring rates. There are LOTS of good reasons to run the softest sways with the correct springs.
Old Apr 30, 2013 | 12:59 PM
CarbonISF's Avatar
CarbonISF
Was just going to say the same thing. I found the same thing too, you need more front spring rate before even looking at the sways.
