oil change
Old Apr 16, 2010 | 11:50 AM
n0th1ng's Avatar
n0th1ng
Hey BigA IS-F how much oil did you get back during the first oil change.. beucase is f takes like 9.8qts which is almost 2 5qts...
Old Apr 16, 2010 | 12:02 PM
BigA_IS-F's Avatar
BigA_IS-F
haha yeah i know thats why i was surprised to get it back. It was a very little amount and i did check the engine to make sure it was at the right level and it was.
Old Apr 16, 2010 | 12:33 PM
Autobacs's Avatar
Autobacs
That is why nothing gives me more satisfaction than doing my own oil change where I know I drain out as much oil as I can (MIN 1 Hour), take off the oil filter and clean off the housing, make sure I prefill my oil filter and put it on just tight enough, and pour in the oil myself.
Old Apr 16, 2010 | 12:35 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by BigA_IS-F
At the Lexus dealership?
No. Toyota where I knew a service manager personally.
Old Apr 16, 2010 | 12:44 PM
Joe Z's Avatar
Joe Z
IS-F uses exactly 10 Qts with new filter........ on a full proper drain.....
Joe Z
Old Apr 18, 2010 | 12:09 PM
lx470man's Avatar
lx470man
Default oil change
im about 500 miles away from my first diy oil change with mobil 1. Well i just searched about diy oil change and it seems like only a few may do their own oil changes. there is like only 2 discussion of oil changes? why? just wanted to know for those that do theirs where they got their drain plug gaskets? i don't want to pay $2.50 for one drain plug gasket! Also if they are just running the cheaper version oil filter on their f? the 04152-yzza3 apparently for the toyota tundra v8. I already bought one so i am just deciding to use it. And prob. get the one for the f, on the next oil change.
Old Apr 18, 2010 | 12:49 PM
itsmike177's Avatar
itsmike177
I perform my own oil changes. I buy the actual oil filter for the ISF, part number 04152-51010 for ~ $8. Drain plug gasket, 90430-12031, $0.80 from local Toyota dealer.
Due to the low clearance of the car, I have to jack up 1 side first. Then slide the heavy duty floor jack to jack up the front via front jack point (crossmember?)
Besides that and the 10 quarts of oil, it's a normal oil change.
Old Apr 18, 2010 | 01:29 PM
lx470man's Avatar
lx470man
i just tried, and well im stoked cause my black rhino ramps on my driveway work well for the f to get up on. I was worried that the front end wouldnt clear but it clears barely.
so mike that filter you mentioned different part number than mine i assume is the one for the f. So can i ask you what lexus dealer only charged you $8 for it? awesome price. And what toyota dealer charged you $.80 per drain gasket? cause the toyota dealer i called wanted $1.70 and the lexus dealer wanted $2.5 wtf!
thanks for the response man. i love doing my own oil changes, it just makes me feel satisifed doing my own work and i know its done properly and i saved some cash money.
also i went to autozone for the sst tool, part number 25404 type f, and is this right? the sst tool is soo small? i havent gotten a chance to see if it is the right size and if it works, but in another thread someone mentioned that this part works fine and is only $5.99! compared to the $38 one at the dealer.
Old Apr 18, 2010 | 03:35 PM
flowrider's Avatar
flowrider
Veteran: Air Force
I change my own oil. Oil filters have been discussed before. Here:
https://www.clublexus.com/forums/is-...il-filter.html
And Here:
http://www.lexusfforum.com/forums/showthread.php?t=1837
In short use the cheaper one, the one for the Tundra. It has parts you wont use, but will do the job just great, and it's OEM quality.
Lou
Old Apr 18, 2010 | 03:39 PM
itsmike177's Avatar
itsmike177
I purchased a pack of 10 oil filters, 04152-51010, on ebay a few months back for $80 shipped.
The crush washers I purchased from Longo Toyota 6 months ago. The parts guy charged me $8 for 10.
As for the SST for the oil filter "cap," I'm just using the same one I purchased for an IS350, about 3 years ago, which is an exact fit for the ISF oil filter cap. Don't mind the picture, it is made of aluminum.
http://www.toolsource.com/0922806501...-p-100298.html
TrueGS300
Jun 25, 2023 01:30 PM
shipwreck
CL of Hawaii
Jun 4, 2012 09:47 AM
KPinCS15
CL of Hawaii
18
Jan 4, 2011 04:39 PM
tieu
Canada
12
Oct 16, 2008 12:09 AM
Jewcano
Maintenance
12
Jun 24, 2006 11:30 AM
