Project Mu Pads
Old Jul 27, 2011 | 04:57 PM
  #181
Evil Teo's Avatar
Evil Teo
my rears are pretty much done. is it good to change only the rear cuz the front has a lot of padding left? i am plannin on gettin slotted rotors as well so I'm not sure of the consequences with mixing pads and rotors from the front and rear.
Old Jul 27, 2011 | 05:07 PM
  #182
Joe Z's Avatar
Joe Z
Lightbulb
Originally Posted by Chops@MVP
I actually just went and snapped some pics for you. Let me resize them and I will post them up shortly!
Regards,
Robert
Thanks Robert.. That was cool of you!!!
You should email your contact there and ask them why the IS-F specific pads are being made this way ??
NONE of the IS-F use "Electronic Wear" sensors....
I never understood why they did that...
Granted I'm running them already, but they really should have just be like OEM full pads..
~ Joe Z
Old Jul 27, 2011 | 11:27 PM
  #183
vraa's Avatar
vraa
CL Folding Team Starter
CL Folding 1,000,000
~ Joe Z
Do you know if these pads fit any other application? Maybe that's why
Or it is some lost in translation issue
Old Jul 28, 2011 | 07:49 AM
  #184
Joe Z's Avatar
Joe Z
Lightbulb
Lobuxracer has stated that our Brembo Calipers are used in at least one other off the shelf OEM application...
It's a Mercedes, that uses our calipers. Their application use the E sensors for the front pads.
Just don't recall the year & model.
There is clearly no reason for that on the IS-F..
So I think (my opinion), their original data collection was pulled from a sample pad they received for the Mercedes Brembo caliper..
~ Joe Z
Old Jul 28, 2011 | 09:07 AM
  #185
Chops@MVP's Avatar
Chops@MVP
Well you guys pretty much cleaned me out overnight. I'm down to 1 full set in my inventory. The supplier has more but there will be a couple days wait time for it to ship to you.
Regards,
Robert
Old Jul 28, 2011 | 10:21 AM
  #186
yemgi's Avatar
yemgi
They were originally on the 2005 SLK55 AMG and CLK55 AMG and have since been installed on the CLK63 AMG These cars have the E sensor that is why the pads have it, aftermarket brake manufacturers did not create a new design for the small market the IS-F is, it is easier and cheaper for them to reuse an existing pad.
Old Jul 28, 2011 | 10:29 AM
  #187
Chops@MVP's Avatar
Chops@MVP
^ Bingo. All pads fall under a FMSI # and that's basically the pad shape/design. That FMSI # will cross to many different cars on most numbers. The lower the application list generally the higher the cost.
Regards,
Robert
Old Jul 28, 2011 | 10:33 AM
  #188
lobuxracer's Avatar
lobuxracer
Tech Resource
Exactly correct on all points.
Old Jul 28, 2011 | 11:05 AM
  #189
Joe Z's Avatar
Joe Z
Arrow
Thanks for the added model info....
I guess if PMU is going through the trouble of making "IS-F" specific part numbers, I would have liked to have seen them made correctly..
But that's just my opinion ..
~ Joe Z
Old Jul 28, 2011 | 04:25 PM
  #190
vraa's Avatar
vraa
I agree 100%
So does this mean I can use pads that fit the Mercedes AMG 55 application?
If the pads fit the caliper, does that mean rotors made to fit the caliper on the Mercedes application will fit our IS-F application?
Just trying to understand how much is intercompatability
Old Jul 28, 2011 | 07:29 PM
  #191
tenspeed's Avatar
tenspeed
The rotors could have the same diameter and thickness but a different bolt circle.
You would have to see if Mercedes and ISF wheels were interchangeable. If they had the same bolt pattern, they would be.
Old Jul 28, 2011 | 10:43 PM
  #192
lobuxracer's Avatar
lobuxracer
Tech Resource
Not at all true. The rotor hat will need to have the same offset, and that's very unlikely.
Yes, you can order Pagid pads that fit the MB and they will work fine in the F on the front only.
More options here.
Old Jul 29, 2011 | 01:08 PM
  #193
Evil Teo's Avatar
Evil Teo
just placed the order for the rear pads and will measure my rotors tomorrow at the dealership.
Old Jul 29, 2011 | 05:30 PM
  #194
Joe Z's Avatar
Joe Z
Lightbulb
I doubt anything besides the pad will work...
Rotor design & hub area are more than likely different.
Joe Z
Old Jul 29, 2011 | 05:35 PM
  #195
Joe Z's Avatar
Joe Z
Lightbulb
More options here.
Even more interesting..
The PMU pads for the IS-F have a Solid Backing plate with just a notched Puck area...
While the Pads for the MB have a notched Backing plate & Puck for the "E Sensors".
Joe Z
