dyno
Old Aug 10, 2009 | 12:15 PM
LEXUSF's Avatar
LEXUSF
Default dyno
What gear should we dyno our car? i hear 5th then some say 6th... what is the true test to see real power? thanks!
Old Aug 10, 2009 | 12:19 PM
Mr Johnson's Avatar
Mr Johnson
6th is 1:1 but some dynos may not like being run up to 172 MPH and I think the stock limiter stops you 100 RPM short of redline in 6th.
Old Aug 10, 2009 | 12:57 PM
Splat's Avatar
Splat
6th gear as stated by Mr J, and Joe-Z. also i bounced off the limiter three times (of the dyno) when doing my pulls.
Old Aug 10, 2009 | 02:21 PM
CrazyMPG's Avatar
CrazyMPG
Phat Monkey
yes...6th gear...
Old Aug 10, 2009 | 02:26 PM
LEXUSF's Avatar
LEXUSF
what have u guys dynoed at?
Old Aug 10, 2009 | 02:41 PM
Joe Z's Avatar
Joe Z
Lightbulb
6th Gear for the IS-F
Find a Dynojet...
Turn OFF Trac & VSC..
Good to have numbers that are graphed SAE Corrected & Smoothing set to 5.
SAE Corrected numbers take all Elements into consideration, when the graph is actually plotted.
Usually, the 3rd to 4th pull in dynos repeated 5-6 times during testing, will also be the one to choose..
You will be able to see the difference in dynos after 2 or 3 of them as the power increases to its peak.
After a 1-2 pulls of decreasing power. You know that its time to end that dyno session.
This will Best represent true RHWP numbers.
(rear wheel horse power)
Dyno's after an engine cool down period (even a few minutes) will cause a spike in rwhp gain. Also, known as inflated numbers.
Good Luck
Joe Z
Old Aug 10, 2009 | 04:23 PM
LEXUSF's Avatar
LEXUSF
Find a Dynojet...
Good Luck
Joe Z
wish i lived in cali! i could just meet up with u guys!
Old Aug 10, 2009 | 06:56 PM
VSL-F's Avatar
VSL-F
I'll Dyno with you DFLORES!! We should get all the Dallas F's in NTL to a Dyno.
Old Aug 10, 2009 | 08:08 PM
LEXUSF's Avatar
LEXUSF
september 6th im going there is a post in the NTL.
Old Aug 10, 2009 | 08:27 PM
DaveMS's Avatar
DaveMS
Did you get that PM I sent you?
finny76
GS F (2016-present)
15
Jul 21, 2019 01:14 PM
pakeeno
RC F (2015-present)
19
Jan 19, 2018 12:30 PM
rselby
IS F (2008-2014)
Oct 7, 2016 11:09 PM
Ramfis
IS F (2008-2014)
13
May 11, 2016 09:13 AM
scrosby
IS F (2008-2014)
17
Apr 8, 2012 05:42 PM
