WTF Lexus
So I installed MobileHID 8k lows and 3k fogs about a month ago and then found out there was moisture on the driver's side headlight. Took out the aftermarket bulbs on the driver's side headlights and switched it with OEM because I took it to the dealership and they said there was a broken seal so I let them fix it. Got it back today and my passenger side fog light seem to be more golden and the driver's side more on the 3k yellow. Did Lexus switched out the bulbs? Or maybe a bulb defect or the ballast? My problem has nothing to do with the fog lights! I'm so frustrated!
Sounds like you didn't take your time installing, and have moisture problems because of it. Make sure that plastic cover is snapped in snug on both sides. In terms of the foglight thing...did you touch the bulbs when u were installing?
Sounds to me that this is a result of something you did not Lexus. We all have to understand that when we mod our cars and something goes wrong, it is our responsibility, not the dealer.
yup. there are a number of things wrong with my car, but i'm not going to go and blame someone else for it.
I had the same problem with my driver side headlight. It got fogged up so I replaced the seal and used a heat guy to dry up the headlight and it works perfectly fine. Seems like you have a ballast issue, contact your vendor and let them know so they can replace it for you.. Oh yeah my retarded Fogs blew already after 3 months.. I'm havent no luck with mod fogs.. Maybe its time to upgrade to JDM FOGS
what type of fog bulb did you get son? You're not supposed put your bare hands on the bulbs because the oil in your hands can hurt the exposure and blow out the bulb. Maybe your lexus dealer used his bare hands and not work gloves, although I highly doubt it because there lexus and they have all that crap. So when you and your friend installed the bulbs, did you happen to touch the bulbs with bare hands or what?
dino
Feb 21, 2007 04:37 PM
