Oil consumption!!!!
Tech Info Resource
I agree, it is not the that the oil will breakdown prior to 10K, modern oils are extensively engineered and hold up extremely well even non synthetics. The reason I change my oil, and I do use Mobil 1, at 3-5k intervals is do to engine blow by at start up which will always add carbon particles to you lubricant. The filter will remove most of the particles but for my piece of mind I believe the $ I spend on the 10 quarts of oil twice a year is well worth it. But with that said each one has to decide what is best for themselves.
Tech Info Resource
