diy light bulbs
is there a diy for changing the interior lights? i am trying to change the nasty yellow interior bulbs.
also the side mirror lights
the fog lights
and daytime running lights
also is there some site were they sell bulbs for cheap and in nice blue to match isf interior lights?
i need this bulb in red for my rear turn signal lights.
[IMG]
[/IMG]
the fog lights
[IMG]
[/IMG]
If you have anymore questions let me know and I can give you some answers. https://www.clublexus.com/forums/sho...d.php?t=387221
https://www.clublexus.com/forums/sho....php?p=3383425 https://www.clublexus.com/forums/sho...d.php?t=385249
hey how did you get that map light swapped out? i tried tp pry the cover off but it wont come. Is there a way to do it that im missing here? i dont want to damage the cover.
Basically you just find a thin card like old credit card of some card you never use anymore and then find a small opening in the light cover. It just pops off after that.
does it matter what end you try to pry the cover off? i mean towards the rear or front of the car?
also did you change out the lights that come on under your side mirrors?
There should be an easier place to insert the card.. it should be thin and strong if possible because I know the one I used brook. But look really close to see if you can find a spot that would be better place to insert the card. The side mirrors are called puddle lamps and no that is the only lights I haven't changed. But if you go to those links I posted a user named Chikken posted a thread on how to change puddle lamps. Go through the links I posted above first and if you can't find it then go directly yo Chikkens page and you can see all of his threads. He has one that give you pictures and everything on how to change the puddle lamps. It is a little difficult. But the interior light are easy. If you still need help let me know.
these are actually the rear turn signal bulbs, does anyone know the part number for this bulb?
also the reverse light bulb part number?
how the heck do you get those clips out for the reverse bulbs, damn i cant get them off and i almost broke them trying, i dont want to have to go to dealer and buy new clips for like $10 a piece.
as far as removing the clips I used a very tiny instrument almost like a screw driver to repair glasses. Try that if that isn't right let me know.
