High Speed Stabilization Issue
Old Apr 14, 2024 | 06:56 PM
  #31
dcguy's Avatar
dcguy
Unrelated to OP’s issue that is now fixed but I had similar issues running different brand tires in the fronts compared to the rears, car would ‘float’ anything above 50 mph and felt unbelievably unstable as the tread patterns of different tires would give different feedback on the road front to back
Old Apr 28, 2024 | 06:25 AM
  #32
itsmike177's Avatar
itsmike177
Supras have always had this issue mostly because the alignment techs fail to use the factory torque specs for tightening the bolts. On the Supra, the front adjustment bolts need to be tightened to 166 ft-lbs. Few techs know this and you have to press them hard to make sure they do this right or the front end goes loose and handling goes to crap quickly. AMHIK.
Thanks lobux, do you happen to know the torque spec for the ISF's alignment bolts for the front and rear? Seems like mine has gone out of whack slightly after 6 months from the previous alignment, which leads me to believe the alignment shop isn't tightening to spec....
Old Apr 28, 2024 | 11:10 PM
  #33
lobuxracer's Avatar
lobuxracer
Tech Resource
Rear Eccentric bolt: 50 N·m (510 kgf·cm, 37 ft·lbf)
There are no adjustment bolts/nuts in the front except the tie rods, and IME those are not torque critical. Two gorilla grunts is plenty, but if you have the right tools, the manual says 56 N·m {571 kgf·cm, 41ft·lbf}.
Old May 1, 2024 | 06:16 PM
  #34
MisterSkiz's Avatar
MisterSkiz
Funny I saw this post - I just started driving back into the office and noticed that on the highway (60-80mph) lane changes or quick adjustments of the wheel make the car float in the lane.
I'm going to put new shocks/springs on the car and have it taken to Lexus to do a once over.
Its either the car is riding on blown shocks or bushings are worn out.....car has 74k on it.
Old May 2, 2024 | 09:16 AM
  #35
lobuxracer's Avatar
lobuxracer
Tech Resource
Or your tires are not inflated correctly, or have damage, or...
My shocks and springs had over 200k on them when I put the Ohlins DFVs on it. I'm sure the OEM units were well worn, but I never had stability issues even with those old things on my car. I'd suspect tires and alignment before spending any money on hard parts.
Old May 3, 2024 | 05:04 AM
  #36
MisterSkiz's Avatar
MisterSkiz
I agree - I just had new Michelin PS4S put on it, and had an alignment as well.
Im throwing new suspension on it as the OEM 08 has really gotten to me as I get older, as well as having the folks at Lexus take a peek over all the bushings,etc on the car.
Jrodd74
IS F (2008-2014)
21
Apr 14, 2025 12:08 AM
YoungPNW
IS F (2008-2014)
14
Oct 24, 2022 04:11 PM
BlueDog007
IS F (2008-2014)
Dec 10, 2019 12:40 PM
kuuqi
Jul 12, 2012 09:09 PM
