IS C Discussion about the convertible IS C model
Cvs problem
Old Feb 8, 2020 | 10:13 AM
Joonasfin's Avatar
Joonasfin
Default Cvs problem
Hello
If this is in the wrong thread you can move it in the right one.
So here is the problem and sorry for the bad english. I hope I can have some help here.
I changed headlight bulb in my 2009 is 250. So when I changed it, I told my girlfriend to try the Lights on if it still work. So she started the car instead and I had removed air filter gasket that includes
maff sensor to get some extra space. Now car says in dashboard " check VCS" and check engine light is on.
I readed fault codes in my carly and then deleted the codes. That helped for a while. But now dashboard says the same thing.
I have no clue what problem might be so I attached codes I got from carly.
Hope I get some help here. Thanks!
Old Feb 9, 2020 | 08:43 AM
primavera's Avatar
primavera
Ask the question in Normal Threads, where the posts get people's attention..
As for the problem I would go back and re-check everything again, vacuum hoses, connectors, air box fitment, light bulb. Seems like something wasn't plugged in correctly.
Joonasfin
IS C
Feb 8, 2020 10:11 AM
Fohxer
Jun 20, 2019 09:02 AM
meadsie
Jan 7, 2018 06:02 PM
P Rock
Jan 13, 2016 09:54 AM
playa3uhh
Dec 30, 2009 08:46 AM
