IS C Discussion about the convertible IS C model
Transmission Service . . . Yea or Nay??
Old Feb 28, 2019 | 12:37 PM
Blahhhster's Avatar
Blahhhster
Default Transmission Service . . . Yea or Nay??
So, your probably wondering where this post is going right?? Well, as most of us probably already know the transmission for the IS 250c is sealed and does not have to be changed according to Lexus. I have done some research and found this is not necessarily the best thing for your car for many reasons. One of which it gets hot and breaks down. There is a great Youtube video with a guy who had great success changing it himself.
However, when I called both Lexus and Toyota for a transmission service the said they only "drain and change the transmission oil". By the way, Lexus wanted double (325.) what Toyota was going to charge (149.)
I found that there is also a transmission filter and gasket inside the pan that can also be changed. The service advisor at Toyota said not to change it because it causes problems. This seems a bit strange since any filter should be changed if your draining the fluid.
Anyone have any ideas or experience with this issue?
Old Mar 2, 2019 | 05:53 PM
Mike_1GO's Avatar
Mike_1GO
i replaced my filter and fluid. no problems and I'm running valvoline maxlife atf
Old Mar 19, 2019 | 05:36 AM
python's Avatar
python
anyone who tells u not to change the fluid is a moron...fluid should be changed no later than 50k and every 30-50k after.
Old Mar 19, 2019 | 10:48 AM
Blahhhster's Avatar
Blahhhster
Thanks. What about the filter?
Old Mar 19, 2019 | 11:18 AM
python's Avatar
python
every other time its serviced
Old Mar 25, 2019 | 08:27 PM
YatesTL's Avatar
YatesTL
8th Gear
Thanks for the post! Which tranny filter manufacturer (Lexus/Toyota or aftermarket) and part number did you get?
Old Mar 26, 2019 | 10:17 AM
Blahhhster's Avatar
Blahhhster
https://www.ebay.com/itm/322012355384
https://www.ebay.com/itm/Genuine-OEM...-/233147237356
Old Mar 26, 2019 | 05:33 PM
YatesTL's Avatar
YatesTL
8th Gear
Many thanks for the quick reply!
Old Jul 18, 2019 | 12:20 PM
FlyRunRide's Avatar
FlyRunRide
Will be doing a drain and refill soon, maybe 2 consecutive times with oil change, then wait for a while and do it again after 50K miles. Thanks for the info.
Old Aug 10, 2019 | 05:51 AM
spineman's Avatar
spineman
So, who hasn't changed their oil and has been fine? Any high mileage IS C's out there??? Being the most reliable brand out there, I think I would trust their maintenance suggestions.
Old Aug 16, 2019 | 06:36 AM
2013FSport's Avatar
2013FSport
Coming up on 85k on a 2013. All seems well but my plan was to dump it at 75 but life got in the way.
As stated by another, not replacing the filter is just senseless. Plus it allows you to get more oil out.
Old Aug 23, 2019 | 02:28 PM
winterturb's Avatar
winterturb
FIWW the ISF service manual in the USA says not to Change the Tranny fluid, yet in Canada they have Service intervals for the same transmission. Same company same car exactly and different recommendations. A drain and fill is better than leaving it and it will last longer than if you don't.
Old Aug 26, 2019 | 11:48 AM
2013FSport's Avatar
2013FSport
As does brakes, diff fluid, engine oil and other things....
Stop and go as well climate and rough roads take a toll on equipment.
gebo
May 27, 2019 03:13 PM
haitianb0i
Jan 25, 2016 06:04 PM
georgie39
RX - 1st Gen (1999-2003)
16
Sep 18, 2009 09:27 AM
Atl
Nov 8, 2007 08:35 PM
palaka
Oct 15, 2007 05:13 PM
