IS C Discussion about the convertible IS C model
Changing reverse light help
Old Feb 6, 2019 | 06:44 AM
OldLs400's Avatar
OldLs400
Default Changing reverse light help
I'm trying to pull the plastic rivets out of the trunk liner which hold the carpet lining to the trunk. I even bought a special trim removal toolkit from Amazon. However, pulling out those plastic rivets is harder than pulling out teeth, even with the trim removal tools. I put so much force into removing one rivet that it shot across the garage floor and I never found it again. I wish I had eye protection on because when it popped loose it could have easily taken out my eye. Are these rivets supposed to be this hard to remove?? Or am I doing it wrong?
Old Apr 11, 2019 | 07:49 AM
benmunger's Avatar
benmunger
You need to push on the center of the tabs first... then they almost fall out.
adrianserb
Oct 20, 2015 03:46 PM
FUZCO
RC - 1st Gen (2015-present)
Aug 17, 2015 11:52 AM
Lex Luga
Feb 6, 2011 06:46 AM
Fizzboy7
Jan 31, 2010 01:57 AM
Toyboy300
Aug 31, 2009 11:33 AM
