IS C Discussion about the convertible IS C model
Adding parking sensors to a 2012 IS350c
Old Mar 8, 2018 | 04:27 PM
roblim's Avatar
roblim
Default Adding parking sensors to a 2012 IS350c
I believe that Lexus offered front and rear parking sensors as an option on the IS350c. I am wondering what parts are needed to add the feature to my 2012 IS350c. Any help is appreciated.
Old Mar 9, 2018 | 01:53 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Parts for 2012 IS350C Clearance/Sonar System:
89340-53050 - Computer, Clearance Warning
90179-06274 - Nut, Clearance Warning Computer (Qty: 2)
89343-30010 - Buzzer, Clearance Warning
89348-35030 - Clip, Rear Clearance Sensor Outer (Qty: 2)
89348-53020 - Clip, Rear Clearance Sensor Inner (Qty: 2)
89348-30030-xx - Retainer Ring, Clearance Sensor (Qty: 6)
89341-64010-xx - Sensor, Clearance Warning (Qty: 6)
82114-53050 - Wire, Front Bumper Clearance Warning
82183-53031 - Wire, Rear Bumper Clearance Warning
Once you remove the bumpers, on the inside there will be outlines of where the holes are supposed to be, these can be cut out to install the sensors.
-xx on the retainer and sensor varies based on colour and is different for each part. If you post your paint code I can tell you the specific part numbers you'll need.
Jeff
Old Mar 9, 2018 | 02:51 PM
roblim's Avatar
roblim
Wow! Thanks so much, Jeff. I have a Matador Red 2012 is350c.
Old Mar 11, 2018 | 07:58 PM
ryanSC300lover's Avatar
ryanSC300lover
Just to clarify, it’s not exclusive to 350C
my 250C has front and rear parking sensors like my Lexus LS
Old Mar 19, 2018 | 03:40 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Very few, if any, options were IS350 specific. You are correct.
Jeff
PhilDWebb
Nov 14, 2017 05:46 PM
pooranji
Jun 25, 2017 02:45 PM
jbone29
May 31, 2017 11:07 AM
bkw
Sep 15, 2006 07:26 PM
ChuH
Aug 12, 2004 03:22 PM
