IS C Discussion about the convertible IS C model
Headlights on 2nd gen ISC
Old Apr 28, 2025 | 01:58 PM
pirate11's Avatar
pirate11
10th Gear
Default Headlights on 2nd gen ISC
Howdy, I have a 2011 IS350C and the headlights are showing their age. Has anyone successfully replaced theirs and had a good experience with after market LEDs? Any recommendations appreciated.
Jim
Old May 13, 2025 | 02:55 PM
wetherby's Avatar
wetherby
9th Gear
Most people I’ve seen go with 2is lights, or the triple beam Vlands.
If you have halogen, I highly recommend Morimoto LEDs to replace the bulbs
Old May 16, 2025 | 09:29 PM
tanweerr12's Avatar
tanweerr12
Nothing will be better than the OEM. My recommendation is have the headlight lens replaced and PPFd so it last longer.
You can go with VLANDS like everyone else. Some people have issues with them.
Old May 28, 2025 | 07:18 AM
victorlee335's Avatar
victorlee335
5th Gear
I bought a pair of Jumiap ones (resold by Fione). I haven’t put them on yet but I’ve heard that these are much better than Vlands. They do have an issue with sealing so you’d have to get them resealed. But the light output is more than OEM and the quality of the bulbs seem fine as well. You do lose AFS
Old Jun 16, 2025 | 07:40 AM
pirate11's Avatar
pirate11
10th Gear
Thanks much. Not really a car mechanic, more a house DIY guy. What kind of shop will do this job? My regular mechanic says not in their job jar.
Old Jun 17, 2025 | 05:40 PM
jj68jam's Avatar
jj68jam
I did the Vlands on my 12' 350ISC and it really updates the look of the car. Unfortunately the passenger side leaked and shorted out one of the two low beams and high beam LEDs (out of warranty)
Good luck with your project!
-Jim
Old Jun 20, 2025 | 08:22 AM
pirate11's Avatar
pirate11
10th Gear
Default lenses
The problem with my headlights is the lenses are deteriorating and sort of yellowish. Anywhere to get replacement lenses?
Old Jun 22, 2025 | 07:57 AM
primavera's Avatar
primavera
I use metal polisher twice a year and it clears them up quite nicely. It's the cheapest way to bring them back to a better look (for couple months). Alibaba sells replacement lenses but those don't fit properly, lol
Old Jul 6, 2025 | 11:15 PM
tanweerr12's Avatar
tanweerr12
you can wet sand them and polish but if they are really damaged then you can get a replacement. The problem is that it is hard to find a replacement set for the 2011+ headlights. I recently purchased a set and they sent me the wrong ones and apparently that is a common experience.
Old Jul 8, 2025 | 01:46 PM
DennisMik's Avatar
DennisMik
Sam's Club will de-fog the headlights for $40. Comes with a 5 year no fog guarantee. Had both my Lexus's done there.
Old Nov 14, 2025 | 06:46 AM
zcollier's Avatar
zcollier
I’m having trouble determining which type of replacement LED bulbs I can put in my factory headlights.
I bought the my 2011 IS 250 used in 2015 and have never had to replace a bulb, which is great, but I want to increase the brightness.
This is what my headlights look like. Are these using halogen bulbs?
Thank you, experts!!
Old Nov 14, 2025 | 10:28 AM
DennisMik's Avatar
DennisMik
Your 2011 Lexus IS likely came with a Bi-xenon (HID) system, which uses a specific type of bulb for both low and high beams. But remove one of the bulbs from the headlight assembly and look for a part number printed or stamped on the side of the bulb. The number will often be a designation like "H11" for HID or "9005" for halogen.
Important note for handling headlight bulbs - DO NOT touch the glass part of the lamp. If you do, clean it VERY thoroughly as the oil from your skin will cause the bulb to shatter when turned on.
bliverson
Mar 1, 2021 05:32 PM
morris
Jun 22, 2015 01:56 PM
RXGS
Oct 15, 2008 04:01 PM
