Some technical info about our 8AT...
Old Jun 23, 2025 | 12:08 AM
G30540i's Avatar
G30540i
Default Some technical info about our 8AT...
AA80E overview
Very good explantation on why our transmission behaves the way it does.
Old Jun 23, 2025 | 02:01 AM
LH1's Avatar
LH1
Nice find! That's a great article.
When I first get going in the morning there's one particular right turn I make that I slow down for. The trans always makes an audible clunk but after that it warms up and is much better.
Old Jun 23, 2025 | 04:55 AM
wthrman2's Avatar
wthrman2
This article and post should almost be pinned given all teh chatter about "why is my transmission so clunky" discussions
Old Jun 23, 2025 | 11:01 AM
arentz07's Avatar
arentz07
Yeah this same article has been posted before in various posts, such as: https://www.clublexus.com/forums/is-...l#post11591907
Can be summed up as: "This is a 20-year-old transmission with compromises because it was the first of its kind". But it is nice to see WHAT those compromises are.
Old Jun 23, 2025 | 11:12 AM
KennyFSU's Avatar
KennyFSU
Short answer: It's cold and old.
Old Jun 23, 2025 | 02:39 PM
wthrman2's Avatar
wthrman2
^^ I use that line on my wife every night!
Old Jun 23, 2025 | 03:31 PM
InveredMP's Avatar
InveredMP
Saw this circling the FB groups. It is a great read.
Old Jun 23, 2025 | 04:52 PM
Benibiker1558's Avatar
Benibiker1558
Interesting that the transmission only has a 8-10 lb-ft of buffer below the max torque rating. What happens when people do mods and increase their torque rating above that? It wouldn't take much to surpass the torque rating .
Old Jun 23, 2025 | 05:12 PM
llO0DQLE's Avatar
llO0DQLE
There's also this
Old Jun 23, 2025 | 07:46 PM
mhh500's Avatar
mhh500
We could just ask the RRR guys to chime in. They've worked on a few supercharged 2UR-GSE/Aisin builds. Honestly, I find it hard to believe that the slow, ancient Aisin transmission can only handle 8-10 lb-ft over its stock output. That doesn't exactly scream reliability, and it's probably the only real advantage this transmission has. However, I do agree the Aisin is (almost) garbage compared to the ZF or other modern transmissions, and reliability is not even a valid excuse anymore; it just feels like Toyota's being greedy or lazy.
Check out his other articles on the 500. He may have a point about a couple of things, but it's pretty obvious he's got something against Lexus/Toyota. Sure, the car's old gen, but come on, he's even picking on the max power output and referencing a short list of SAE-certified engines. Something about that just doesn't sit right.
Old Jun 23, 2025 | 07:50 PM
InveredMP's Avatar
InveredMP
The rated torque limit is really just a number. It could mean that they only tested it to those torque settings or it can simply be a conservative number. These transmissions are essentially bulletproof, I don't think I have ever seen one fail.
Old Jun 23, 2025 | 08:10 PM
05RollaXRS's Avatar
05RollaXRS
I was going to point that out earlier. Beware of misinformation in the article.
Many of us modded with bolt-ons, are making more than 406 ft-lbs to the crank. Full bolt-ons are making much more up to 490 whp and around 422 wtq in the case of a few RCFs. Then there are supercharged 2UR that make upwards of 600+ whp and a lot more torque than N/A mods can allow. The transmission is extremely reliable and can hold much more torque than 406 ft-lbs while being reliable contrary to what the article claims.
Old Jun 24, 2025 | 05:09 AM
TGPCanada's Avatar
TGPCanada
Yeah, I have an extraordinarily hard time believing they made the design margin so tight. The engineering Lexus puts into these vehicles is the highest quality. Also, we've not heard of transmission failures over the many years this unit has been in service through multiple, different vehicles.
Old Jun 24, 2025 | 06:55 AM
Benibiker1558
Yeah, you can tell writer has a bone to pick about the transmission. Everyone makes a good point about its reliability and that speaks volumes.
Old Jun 24, 2025 | 09:18 AM
cyfi66's Avatar
cyfi66
While there's a lot of technical info in the articles on that website most of them seem be 50% opinion piece and 50% tech review, with a bias against the IS500 for some reason.
Even if the 8-10ftlb buffer thing is true more than likely thats 8-10ftlb from the safety factor limit, meaning there's a safety margin built in. A google search shows typical safety factor for automotive is around 3, meaning they would build things to tolerate 3x the max torque output expected. Nobody is using a transmission in a vehicle that is 10ftlb's away from destruction.
