Sun Visor extension
Old Sep 26, 2025 | 11:52 AM
dnujra's Avatar
dnujra
1st Gear
Hi @isfree very informative post thank you! It's tough to tell from photos but looks like in some of them the perfect black may be quite close as well, if you did it over again would you stick with ebony?
Old Oct 10, 2025 | 12:27 PM
isfree's Avatar
isfree
Perfect black is pretty close too. I'd still go with ebony. You won't noticed a color difference when its installed in the car.
I probably would try to just ignore the warning stickers if you can, because I didn't cut it that well and the edge is fluffy. Maybe scissors would be better than a xacto knife.
Old Oct 25, 2025 | 05:50 PM
TurkEclips's Avatar
TurkEclips
Can you reuse the screw cover from the IS or do you need to use the one from the NX?
Old Oct 25, 2025 | 07:31 PM
oceanp's Avatar
oceanp
the is is a perfect fit, just be carefull popping it off
Old Oct 27, 2025 | 12:46 PM
BChoCRNA's Avatar
BChoCRNA
I wonder if the new refreshed IS will come with sunvisor extenders.
Old Nov 30, 2025 | 12:51 PM
TurkEclips's Avatar
TurkEclips
Originally Posted by isfree
No need to go aftermarket, just get the extending sun visors from a 2022+ Lexus NX. Part numbers 74320-F6010-C0 and 74310-F6010-C0
https://www.clublexus.com/forums/is-...l#post11706089
is the left the drivers side. Thinking about trying to change just the drivers side only
Old Nov 30, 2025 | 06:22 PM
oceanp's Avatar
oceanp
That's what I did, very easy to install
Mikethebike
Nov 10, 2024 06:13 AM
DEL92
RX - 5th Gen (2023-present)
Mar 1, 2024 09:11 PM
PGARazor
Performance
Mar 29, 2017 10:01 PM
Hoovey689
May 17, 2010 09:33 AM
