Rear differential fluid change
Old Feb 16, 2023 | 10:36 AM
tvnguyen's Avatar
tvnguyen
Default Rear differential fluid change
How often should this be changed (mileage or time intervals) in a 2014 IS350 AWD? Also, what are people paying to have this service performed? Thanks in advance.
Old Feb 16, 2023 | 11:11 AM
UNDRP4ID's Avatar
UNDRP4ID
4th Gear
I just picked up a 2016 IS 300 last week and was told by the dealer the front and rear differential fluid needs to be changed soon. They said every 7yrs or 100,000KMS.
I called a couple Lexus dealers to find out pricing and some were charging close to $180 (Canadian dollars). Keep in mind this price is just for the front. Rear would be another $180.
Call a couple dealerships though cause I found one that was only charging $100.
Old Feb 16, 2023 | 12:14 PM
tvnguyen's Avatar
tvnguyen
Thanks for your response. Figured the cost would be in that ballpark. Guess I'm due for one.
Old Feb 16, 2023 | 04:36 PM
laobo979's Avatar
laobo979
I do mine at every 30K and it a pretty easy job to DIY.
Old Feb 16, 2023 | 04:38 PM
JNP1227's Avatar
JNP1227
I change mine every 60k. Would also change the breather valve while you do the fluid. Easy to swap and pretty cheap.
Old Feb 16, 2023 | 08:19 PM
richieca's Avatar
richieca
You can pay or do it yourself its very easy. Drain and fill is all thats done. If you havent done it before then you havent experienced the joy of smell of differential fluid.
Old Feb 17, 2023 | 05:30 AM
tvnguyen's Avatar
tvnguyen
Good to know, will look around the forum for a DIY. Thanks!
Old Feb 17, 2023 | 11:53 AM
swaangin's Avatar
swaangin
Rear diff every 30k, front diff (if AWD) every 60k
Old Jun 19, 2023 | 05:00 PM
Oneops's Avatar
Oneops
Curious if anyone changed before the 30k. Only and 17k currently but was thinking about changing them when I’m doing next oil change this week. Same for the trans and t case.
I guess the the thought was break in and change it even early then this. Or it that not much a thing to worry about?
Hues10
Aug 26, 2025 06:27 PM
stevelifts
Aug 10, 2019 02:10 PM
ajay60610
Sep 25, 2013 07:21 PM
BinaryJay
Aug 17, 2011 10:52 AM
carguy07
RX - 1st Gen (1999-2003)
13
Jul 29, 2008 06:01 AM
