2017 IS200t Notchy Steering Issue - Please Help
Old Dec 3, 2022 | 12:14 AM
sunamer's Avatar
sunamer
Originally Posted by arentz07
Open question for anyone who is having this issue about an observation I've noticed recently.
If I wiggle the steering wheel back and forth while the car is stopped, I can feel it "catching" in certain spots. I have noticed two spots - one that is somewhat to the left of center, and another that's to the right, but slightly father off-center than to the left.
Does anyone else have the same phenomenon occur in their car?
I think if you are doing it stationary and quickly enough, you are going to feel the EPS itself rather than that binding issue.
That is to say, you turning the wheel and the assist kicking in will have a slight mismatch, so you will feel a larger force required to move the wheel initially, but then later, after the system detects that you actually need assistance, it provide it, thus reducing required manual effort. It is probably less than 200ms time difference.
If you do it quickly enough, you can feel it "catching", but I don't think it is the same problem.
Also, can you try rotating steering wheel of center (like by 90 deg) before you do your experiment?
Old Dec 4, 2022 | 08:05 AM
arentz07's Avatar
arentz07
Gotcha.
I tried doing it with the wheel turned pretty far to the right - maybe 30-40 degrees, and it didn't seem to be the exact same feeling - much more subtle I want to say? There were definitely specific spots where it was most noticeable.
Also, it made a scrubbing noise when I did it that far over. However, the car was cold, and I tried it again later - no weird noises.
Old Apr 13, 2023 | 10:37 AM
Yahya's Avatar
Yahya
7th Gear
Originally Posted by Joshlee73
Hey guys, before you ask - yes I did search the board and found a few posts on this but I want to run it by you guys anyway.
I have owned my beloved IS for about two years now but yesterday was my first long distance trip. I noticed that above 70mph on long straightaways that if I needed to change lanes the electric power steering felt like it went to sleep; it would feel almost notchy, like I needed to overpower some sort of detent. It happened so bad that the car felt like it was gonna get a little squirrely on me. The thing is - if I slowed down well below 70, the problem in fact went away, did not need to cycle the ignition or anything it just went away. It would then return above 70 but not immediately.
So, no warning lights on the dash. 62K miles on the clock. No modifications to the car, bone stock. Car drives straight and normal. No strange wear patterns on the tires and car was recently serviced and inspected.
One post said that the fix was to ultimately replace the steering rack: https://www.clublexus.com/forums/is-...long-post.html
My question is: how can this be a mechanical problem if it only occurs above certain speeds for sustained intervals? It really sounds like a software issue to me but I have found nothing about it, only to replace the rack.
Please help. I am actually a little concerned about driving the car long distance again that it could become a safety issue. Thanks in advance.
hi there i am getting the same issue here on my 2018 Lexus is300 f sport RWD.
it is annoying, I’ve seen one youtube video which shows a connection down might be lose, I didn’t tried it, my car only 46k miles any one knows what could be the issue !
Old Apr 14, 2023 | 08:32 AM
sunamer's Avatar
sunamer
I doubt it is a connection issue. I pulled a fuse for EPS in my 2015 is350 and it still had the same issue - highway steering notchiness feel.
Old Apr 21, 2023 | 02:30 PM
manataur's Avatar
manataur
7th Gear
2016 is200t and mine does this on the interstate also
DoTheDrew
May 11, 2024 07:04 AM
davidtth
Nov 2, 2022 09:02 AM
silbercar
May 3, 2022 02:31 PM
4889lx570
LX - 3rd Gen (2008-2021)
Jun 15, 2015 11:43 PM
jdog0411
Feb 13, 2011 10:38 PM
