3IS AWD Rear Differential Vent Value
Old Nov 16, 2022 | 06:54 AM
JNP1227's Avatar
JNP1227
Default 3IS AWD Rear Differential Vent Value
Has anyone replaced the vent/breather value on the rear differential? Does it require to drain the fluid first or is it simply remove and replace? Part itself is relatively cheap.
Dealer said mine is seized and will require replacement otherwise the axle seals will start leaking.
Old Nov 16, 2022 | 07:21 AM
Gerf's Avatar
Gerf
On most cars they are threaded in on the top of the diff housing, draining the fluid is not required. it's pretty common for the cap on top of the vent to get corroded or plugged up with crap and the best thing to do is replace it. You can put pliers on the cap and try to rotate it free but that wont tell you if the passage into the diff is plugged or not.
I would soak it with penetrating fluid before trying to remove it.
Old Feb 28, 2023 | 12:13 PM
JNP1227's Avatar
JNP1227
Only issue dealer found is that it is corroded but they don't want to replace it because they fear it may break or partly crumble and fall into the differential. They don't want to own that which I don't blame them. New diff is $$$$
MAC420SWAD
Jan 5, 2022 07:24 PM
Vinnyp10
Jul 12, 2018 01:40 PM
alain173
Dec 6, 2016 05:44 AM
WM711
Sep 28, 2012 08:41 PM
hugo2648
RX - 1st Gen (1999-2003)
Jul 23, 2007 06:40 AM
