Are 21+ IS350 Tunable?
Old Jul 25, 2022 | 10:44 AM
NateDogg79's Avatar
NateDogg79
Default Are 21+ IS350 Tunable?
Hello, was wondering if anyone know if the IS 350s are tunable? If not do all these plug and play tunes work? If so which ones do you guys recommend?
Thanks
Nathan
Old Jul 25, 2022 | 11:43 AM
JNP1227's Avatar
JNP1227
Thanks
Nathan
Dont think anyone has come out with a tune yet. I haven't seen any reputable tuners release any information on this.
Old Jul 25, 2022 | 12:24 PM
swaangin's Avatar
swaangin
Don't think the tune is available for even 2018+ IS either
Old Jul 25, 2022 | 02:40 PM
Tamtino's Avatar
Tamtino
I would try asking around your local tuners
I have 2 tuners that would be able to tune my 22 IS if I provided them the software
Old Jul 25, 2022 | 06:17 PM
arentz07's Avatar
arentz07
What software are you referring to?
Old Jul 26, 2022 | 06:47 AM
Fman2118's Avatar
Fman2118
None available so I traded in my 2021 IS350 for an IS500. No tuning necessary. 😎
Old Jul 26, 2022 | 07:42 AM
JNP1227's Avatar
JNP1227
Wondering if its one of piggyback tunes someone else mentioned in another thread that had terrible reviews
Old Jul 26, 2022 | 08:21 AM
arentz07's Avatar
arentz07
I'm not sure how a piggyback tune works with our V6. Maybe it was for an IS 300 turbo.
Old Jul 26, 2022 | 08:41 AM
JNP1227's Avatar
JNP1227
It is essentially a chip tune thru OBD port...few vendors out there that have this or are marketing this. Not sure if anyone here can verify it works.
For sure no one has a ECU ReFlash Tune similar to RR Tune.
Old Jul 26, 2022 | 08:47 AM
arentz07's Avatar
arentz07
Re-flashes are typically done through the OBD port, so maybe that's it? Do you have an example vendor?
Even on my old GTI I refused to run a tune like that or even a piggyback - I did a re-flash. But, with the nautrally-aspirated engine in the 350 I don't think a piggyback really works. That's one drawback of NA power... not much you can do without modifying hardware most of the time. You can, of course, increase the rev limiter on these engines relatively safely, which gives you more "area under the curve", i.e. more time spent near peak power.
Old Jul 26, 2022 | 09:57 AM
JNP1227's Avatar
JNP1227
Check out this thread
https://www.clublexus.com/forums/per...ance-chip.html
Old Jul 26, 2022 | 10:58 AM
arentz07's Avatar
arentz07
Yeah that looks like a straight-up fake product. There have been countless videos exposing these "chips". Anything that costs less than $100 and is called a "chip", other than a reputable company like RaceChip, for instance, is more than likely scamming people.
Old Jul 28, 2022 | 10:19 AM
Rhydg1's Avatar
Rhydg1
D3 Apparently has one for the 2018+. No first hand with it, but there are a handful of people on here that have it. https://d3performance.net/index.php/...ormance-tuner/
Allannss
Apr 1, 2026 10:26 AM
E06IS350
Oct 27, 2021 08:01 PM
dangy
Mar 4, 2012 02:34 AM
ShiftyD2k
Jan 31, 2012 06:36 PM
karasha
Jul 25, 2010 01:26 PM
