Open the hood and look bottom !
Old May 18, 2022 | 10:35 PM
bartucelik's Avatar
bartucelik
Default Open the hood and look bottom !
Hi guys I have a 2014 lexus is350 awd f sport
all stock 76k miles
just curious , when I open my hood and check engine bay area I can see thru all the way to the asphalt
I think there must be a cover underneath the car or am I missing? Or the underneath plastic cover is just below the radiator area?
Old May 19, 2022 | 10:37 AM
arentz07's Avatar
arentz07
all stock 76k miles
Without a photo, I would have to guess that this is normal. Basically every car I've owned has had some sight line to the ground from the engine bay, though how much you can see will vary.
Do you have a photo?
Old May 19, 2022 | 10:50 PM
bartucelik's Avatar
bartucelik
I tried to take a pic but you can’t really see on the pic
you have to really move year head around to see the ground but some certain angles like i can see the axle boot of driver side
I thought the underneath of the car is completely covered before
guess its normal too see then
thank you
Old May 20, 2022 | 05:19 AM
Sasnuke's Avatar
Sasnuke
While the engine bay is covered underneath it's more around the perimeter, the area under the engine itself is open, so inevitably you will be able to see the ground in some spots from above.
It shouldn't be much and only in certain places...sounds like what you are seeing is normal.
Rumguy
Feb 22, 2018 03:59 AM
cHiTwNGS43
Nov 24, 2014 12:51 AM
brettno1
Sep 10, 2011 09:30 PM
vuthanh
Jan 21, 2011 07:27 PM
rhsmd
Jan 28, 2007 02:35 PM
