View Poll Results: Anyone else have this issue
Did lexus help you?
0%
What did you have to do to fix the problem
0%
Any advice
0%
Would you agree that this was caused by lexus and as such should be fixed by lexus
0%
Voters: 0. You may not vote on this poll
Head damage caused by Inform update
Old May 2, 2022 | 12:34 PM
Kumler's Avatar
Kumler
5th Gear
Default "Infotainment System" crash caused by Inform update
Has anyone else had this issue? If so, what were you able to do to fix the problem? What did Lexus do to help?
Rick
Old May 3, 2022 | 04:51 AM
Jwconeil's Avatar
Jwconeil
What is an inform update, and what kind of head damage? Is it on one bank or two?
The head functions mechanically. The timing is tied to gears, and engine oil pressure helps it all move and sing. It’s very hard to imagine a software update hurting your heads, but there are smarter people on this forum than me.
Old May 3, 2022 | 05:37 AM
Kumler's Avatar
Kumler
5th Gear
Default Sorry, I guess it should be titled "infotainment System Crash"
[QUOTE=Kumler;11280273]Has anyone else had this issue? If so, what were you able to do to fix the problem? What did Lexus do to help?
I saw it called several things and "Head Damage " was the most common. I failed to realize it would be mistaken for the engine head. The inform software is what is used to run the Map, Media, wifi and Phone. I believe they are talking about the Hard drive head which runs those systems.
Rick
Old May 3, 2022 | 09:11 AM
b15's Avatar
b15
[QUOTE=Kumler;11280803]
Rick
What year is your car and did you attempt to update yourself? If so I'd say you're on your own.
Old May 3, 2022 | 09:18 AM
Kumler's Avatar
Kumler
5th Gear
It is a 2014 IS250
it was a wifi download from Lexus Inform
Old May 3, 2022 | 09:30 AM
msgs350's Avatar
msgs350
This is the "F" sub-forum so we might not be as helpful with this odd (at least to me) issue with firmware damaging a motor component.
Old May 3, 2022 | 09:33 AM
lakai5's Avatar
lakai5
He means head as in head unit lol, but his infotainment setup is different than ours, yeah this is in the wrong forum
Old May 3, 2022 | 09:40 AM
msgs350's Avatar
msgs350
ha! Reading comprehension is hard today for me today.
Old May 3, 2022 | 10:29 AM
Kumler's Avatar
Kumler
5th Gear
Default Inform data update took out the head unit that controls the map, wifi, phone and medi
This was a wifi update requested by "Inform" when update was completed it just keeps turning on and off again. Never rebooting
Old May 3, 2022 | 06:09 PM
arentz07's Avatar
arentz07
This seems like an issue with the head unit. What year and model do you have? Maybe a little more about what you have tried would also help us to narrow down the problem.
I would also add that, to prevent further confusion, OP is referring to "Enform" which is the remote services software in these cars.
HeavenSold
NX - 2nd Gen (2022-current)
129
May 16, 2023 05:47 AM
JNguyen9
CT 200h Model (2011-2017)
Dec 23, 2021 08:58 AM
PSLEXUSES
ES - 7th Gen (2019-2025)
22
Feb 4, 2021 12:15 PM
JunLi
Jun 12, 2016 08:49 PM
cowpatty
Apr 24, 2011 08:42 AM
