brake pad/rotor mystery
so my 2017 lexus is350 Fsport has about 50K KM. That's about 31K miles.
in this 50K Km of driving, i changed my rotors and pads 4 times. YES 4 times. i have no idea why but my brake pads just keeps finishing quick.
The first time i changed it was after 20K KM. i replaced the pads only to EBC redstuff, but didn't change the rotors, after driving few days, the vibration was extrmely bad when i pressed the brake. I'm assuming it's the ebc pads digging into the old rotors. They werne't resurfaced.
so after that happened, i just bought brand new OEM pads and rotors and changed it and they lasted 15K KM. I changed all 4 again and some reason i kept getting lot of brake dust and felt some vibration so i changed it again to Akebono and centric rotots. It was running fine at first, then after 6K KM, (Now) when i press the brake, i feel the vibration on my pedal.
I don't understand what's happening. yes, i won't like i do brake a little hard at times but i don't understand why it's vibrating? are the rotors warped? do all my rotors get warped because i brake so hard often and the pads heat up the rotors and then eventually warps?
I am not planning to buy front EBC yellowstuff and new rotors. I just don't know which brand rotors i should go with. the vibration is bad and it's annoying.
Sounds like your rotors are warped or need to be resurfaced. If you feel wobbly/vibration/shudder only when braking especially at higher speed, it’s usually a sign of bad rotors. Try getting new rotors or resurfaced rotors and akebono brake pads. The pads last a lot longer and give less dust. Turn your resurface your rotors when the pads need to be changed.
As I've posted (first many years ago), the IS F Sport uses Professional German BMW/BMW-Style pads from a BMW supplier. High wear, high friction, high performing.
Cost of doing business.
It's exactly what you signed up for. Wear it like a badge of honor. When I had my 2016 IS200T F Sport brand new from the dealer, I replaced my first set of front pads at 11,000 miles.
You have to pay to play.
Want longer wear? You'll get reduced performance.
"Nothing comes for free."
-E46CT
-E46CT
Not too sure about post since there have been many people who've been able to get plenty of life from the rotor but pads are a bit of a different story. I think your issue is definitely abnormal and you may want to check if any of your calipers are seized.
Recently, I got my job done at a super cheap shop, they did my pads + rotors all around and my rear pad on my passenger side exploded (brake dust and metal to metal scrap all over my new wheels). They didn't put any lubrication where they were supposed to in the caliper and it seized. Fixed the caliper and just swapped REAR pads and the rotor is still good, no shakes, even AFTER metal to metal contact. The pads may wear every 15-25k miles but the rotors I think should be around 40-50k miles. Don't change your rotors if you don't need to
It's possible the calipers are dragging the pads all the time. I bought a used 2010 Camry back in the day, and it had this problem when I bought it. Within a month my brakes needed changing, even though they were OE Camry pads and rotors with only 20,000 miles on the car. Luckily my dealer smelled a rat and looked into the problem. Fixed it under warranty.
I had a 2016 IS 300 AWD F Sport and the brake pads lasted me 30,000 miles, and I needed to resurface the rotors just once.
I agree with @arentz07, there's probably constant drag on the calipers, which possibly means that there might be some kind of obstruction in the brake system that's preventing the fluid from flowing freely. Pressing the brake pedal forces brake fluid to the calipers. But when you let off the brake pedal, there's only residual vacuum within the system to pull the brake fluid back from the calipers to release pressure against the caliper pistons.
YMMV.
