Parking Camera - Lexus is 300h
Old Apr 8, 2022 | 12:49 AM
Edvin32's Avatar
Edvin32
Default Parking Camera - Lexus is 300h
Hi guys, my lexus is 300h did not have the oem parking camera installed as an optional extra. Anyhow, i bought an aftermarket one specifically to suit my model, does anyhow know a route through which i can run the cable from the back out to the center console? It does not necessarily have to be for IS 300h specifically, i assume same would apply for IS 350. I would ideally, if at all possible opt to go the standard oem route. Any info on this would be hugely appreciated.
I would presume the camera cable would need to run from the back to the center console, or could Lexus have left a cable going from the center console to the trunk which the camera could simply plug into?
Old Apr 8, 2022 | 03:56 PM
387's Avatar
387
Did you pull the trunklid liner to see if your car is prewired with a plug? If so, you just clip/tap into the wires using the wiring diagram from a thread floating around here. I did it myself recently with a $50 camera off Amazon that looks OEM.
If your car is prewired for it, the only reason to get into your center console is if the camera actually needs 12v IIRC, you can't get 12v from the connector or the reverse lights since is less than that, I believe they are between 6 and 9v.
Old Apr 8, 2022 | 03:59 PM
Edvin32's Avatar
Edvin32
No i did not. Will check to see if it is pre-wired. Would you expect it to be, i mean was yours?
Old Apr 8, 2022 | 07:59 PM
387's Avatar
387
My car did not come with one, but luckily I found a connector and was able to tap into the wires.
Hopefully you will be able to find one too.
I drilled into the plastic trunklid trim and the trunk lid to feed the camera harness through, it was very simple.
Old Apr 8, 2022 | 08:10 PM
387's Avatar
387
Old Apr 8, 2022 | 08:13 PM
387's Avatar
387
Old Apr 20, 2022 | 02:05 PM
Edvin32's Avatar
Edvin32
I am attaching a screenshot of the camera i bought (still being shipped). Did you have something similar?
That specific thread you mentioned in your initial post, the one with the wiring diagram, any chance you could send me a link to it?
Old Dec 12, 2024 | 03:30 PM
hadikhanniazi's Avatar
hadikhanniazi
1st Gear
Default Putting in a OEM Reverse Camera
Is there a way to connect an OEM camera so that I don't need to cut wires or make a hole in the boot of my Lexus IS300h? Thank you.
hzhao
GX - 2nd Gen (2010-2023)
58
Dec 5, 2025 07:20 PM
DavidZ
ES - 7th Gen (2019-2025)
May 9, 2020 10:02 AM
doodlebug
Dec 11, 2013 09:07 PM
jaydude132
Feb 20, 2010 05:20 PM
Sexi_Lexi
CL of Southern California
21
Apr 16, 2008 05:07 PM
