Servo Motor Replacement In UAE
Old Aug 9, 2021 | 05:43 AM
starrk1982's Avatar
starrk1982
10th Gear
Default Servo Motor Replacement In UAE
I wanted to ask expertise about a car workshop having a specialty in repairing A/C electrical & mechanical for Lexus in the United Arab Emirates which is also at the level of dealer repair?
I have problem with servo motors which I need to replace in my car and wanted a cheaper option than the dealer.
Old Aug 9, 2021 | 05:50 AM
Matroushi's Avatar
Matroushi
I've done them at Dynatrade and I would recommend them.
Old May 4, 2023 | 08:11 AM
WaCKiLL's Avatar
WaCKiLL
3rd Gear
Did you manage to get it fixed? If so, where did you go and how much did it cost?
Old May 5, 2023 | 03:39 AM
starrk1982's Avatar
starrk1982
10th Gear
I had it replaced at the agency and cost me around 7000 AED, of course it also discounted price.
Are you facing similar issue ?
Old May 5, 2023 | 04:05 AM
WaCKiLL's Avatar
WaCKiLL
3rd Gear
Yes, I checked with the service center, 4 out of 7 servo motors are faulty and need to be replaced. However, they’re charging about 7k, so I’m trying to find an alternative.
I realized the issue after noticing that the AC recirculation option is faulty - outside air comes through the vents.
Old May 5, 2023 | 04:12 AM
starrk1982's Avatar
starrk1982
10th Gear
Although Dynatrade is an alternative, many repair facilities, including Dynatrade, advise that it is always preferable to replace the full motor set. In my case, I had to replace all seven, not just four. This issue is widespread in Lexus vehicles; in fact, the US voluntarily recalled most of the 2012 till 2017 models to replace the servo motors. The main corporation in Japan has not yet sent the local agency any orders.
Old May 5, 2023 | 04:30 AM
WaCKiLL's Avatar
WaCKiLL
3rd Gear
Yes! That’s exactly what the service center said, they have to replace all 7. Its not that urgent, so I will delay and continue looking for better alternatives. There must be some Lexus specialized garage that could solve this issue for under 2k. If not, then I’ll have to turn to dynatrade for a quotation eventually.
Old Jun 27, 2024 | 12:33 PM
SalmanAsif's Avatar
SalmanAsif
1st Gear
Default Lexus gs 350 Servo motor replacement cost
Any suggestions in UAE.
Old Mar 17, 2025 | 09:39 AM
mahenzi's Avatar
mahenzi
3rd Gear
Hey. Did anyone find a cheaper solution here in UAE? I am having the same issue.
Old Mar 19, 2025 | 11:05 PM
DrVink's Avatar
DrVink
10th Gear
Sometimes it helps to reinitialize them. I had the same problem, and after running the diagnostic (built in, google it), they started working again.
Old Mar 19, 2025 | 11:11 PM
mahenzi's Avatar
mahenzi
3rd Gear
I tried it. I have Techstream the latest version. Seems like all of the servos are working but even after initialization they are forgetting the position. I have changed the AC amplifier too. I have no idea what is happening.... Thanks for your answer tho.
Old Mar 19, 2025 | 11:49 PM
DrVink's Avatar
DrVink
10th Gear
Try this, I couldn't find the thread, so here's the screenshot. I have a GCC car too, it worked it my case, even though it is just a diagnostic.
Spoiler
Old Mar 19, 2025 | 11:53 PM
mahenzi's Avatar
mahenzi
3rd Gear
Will try it in the evening and let you know. Thx
Old Apr 23, 2025 | 11:22 AM
Isadavi23's Avatar
Isadavi23
5th Gear
Default Help !!!
Would this servo issue cause the nav/radio not to work and display a climate control system error
Geebr200
RX - 3rd Gen (2010-2015)
May 7, 2021 09:30 AM
DshngDaryl
Jul 13, 2020 05:39 PM
pab12
Dec 18, 2019 05:24 AM
klein4896
May 17, 2009 01:43 PM
