replacement shocks for lowered 3is
those of you with RSR springs only, non-coilover .... what replacement SHOCKS have you all gone with?
my 2016 only has about 42k miles .... had RSR DOWNS(LCAs and rear camber arms) on for about 2 months. . . 200miles-ish.
this is more of a proactive upgrade vs something that is "wrong" or happening with the car now. just got an alignment and the tech mentioned that my rear shocks are soft.
my 2016 only has about 42k miles .... had springs on for about 2 months. . . 200miles-ish.
PTR13-53093 (Right front)
PTR13-53094 (Left front)
PTR13-53140 (Rear)
AFAIK there's no aftermarket replacement shocks for the 3IS, and if there are, none made to work with anything lower than the F Sport or Tein H techs which are a Professional/Adult 1" drop (no more.) anything lower is typically out of the comfortable oscillation range of stock dampers and will usually overwork and overheat them quick, toasting them.
This and several other reasons beyond the scope of this discussion (and I do mean several) are why one should not go lower than the Blue F Sport springs which are 1"
Unless a company like Bilstein comes out w/ sport dampers meant for lowering applications (they make them all day long for the euro crowd) i wouldn't go beyond 1".
You could get new F Sport shocks and they'd last a little while but probably lose optimum performance around 20k. don't be shocked (hah)
(lots of suspension building, damper rebuilding experience here)
AFAIK none made to work with anything lower than the F Sport or Tein H techs which are a Professional/Adult 1" drop (no more.) anything lower is typically out of the comfortable oscillation range of stock dampers and will usually overwork and overheat them quick, toasting them.
Subscribed to this thread as I will likely need to replace mine at some point (rsr downs on OEM shocks, so far so good)
interested in this as well but i looked up on ebay and i believe the OEM part is around $115 shipped. i installed the springs around 35K miles, car still rides good i'm at 56K now
https://www.ebay.com/itm/36316167780...temCondition=3
I Installed springs at 40K miles, I'm at 72k now and still feels good
I speed a lot (hate to admit) but when I come on a road with a 'hilly' surface, not bumps, my car feels like it's bouncing lol, feels almost unstable but besides that it's good
They have Super down springs which go lower but I was basically rubbing on RSR down w/ 25mm spacers and after my alignment I've been good. I feel like any lower, I'm 100% rubbing which I do not want.. so you can go lower but for me, it's too much if I want flush fitment on my OEM wheels
I've paired the f-sport bilstiens with swift springs - it's a great combo. it mutes much of the road imperfections while providing confident placement. also for me, going to a tire that is designed for the wheel eliminated most of the "bouncy" feeling over humps
