Need help
Old Mar 6, 2021 | 09:46 AM
Larry373's Avatar
Larry373
Default Need help
2016 IS300 Lexus I unplugged the camshaft position sensor on driver side by oil cap and the wires came out of the connector I need to know what order the wires go back in the connector I have three wires one light gray one white and one purple
Old Mar 6, 2021 | 09:53 AM
Larry373's Avatar
Larry373
If any pictures would be appreciated
Old Mar 6, 2021 | 10:10 AM
NickCaesar's Avatar
NickCaesar
Gr
grey wire closest to oil cap, white middle, purple far driver side.
Old Mar 6, 2021 | 10:14 AM
Larry373's Avatar
Larry373
Thank you so much picture is purfect
Sasnuke's Avatar
Sasnuke
Are the terminals still on the ends of the wires? Cause they should be able to come out of the connector at all.
Old Mar 6, 2021 | 10:21 AM
Larry373's Avatar
Larry373
No ends just wires
Old Mar 6, 2021 | 10:23 AM
Sasnuke's Avatar
Sasnuke
No ends just wires
That's not good. You're going to need to reattach the wires to the terminals.
The easiest thing to do now is get 3 new terminals which will come with wire on them...you can then join them to the existing wire with solder and heat shrink.
Old Mar 6, 2021 | 10:32 AM
Sasnuke's Avatar
Sasnuke
If you do need to replace the terminals, the part number is 82998-74030.
You'd need 3 in total. The wire is 1.6mm thick, so heat shrink for that size would be good.
Old Mar 6, 2021 | 10:44 AM
Larry373's Avatar
Larry373
I'm getting a new connecter and wire it in that's for all the info
Old Mar 28, 2021 | 01:42 PM
Indycar's Avatar
Indycar
Exclamation 2018 IS350 Camshaft Position Sensor Wire Order
I have the exact same problem with my 2018 IS350 but the wires for this year are Blue, Red and Black. Does anybody have a photo of the order these wires going into the connector?
Ken
Wires got pulled out of their connector during a spark plug change. Bought a new pigtail connector. Just no idea what order they go in.
Old Mar 28, 2021 | 03:30 PM
Sasnuke's Avatar
Sasnuke
Ken
Check the other thread you started...the wires are Light Blue, Brown, and Black btw
Old Mar 28, 2021 | 03:38 PM
Indycar's Avatar
Indycar
I just hit 57k and my gas mileage was steadily decreasing after all other filters changed and map sensor cleaned
Nismoz
Feb 15, 2020 02:51 PM
chi123
Feb 9, 2012 07:51 PM
