Knock/Pop After Coils Installed
Old Feb 6, 2021 | 02:59 PM
Chunkyyy's Avatar
Chunkyyy
6th Gear
Default Knock/Pop After Coils Installed
Hi All,
I had RSR coilovers, Bjoint, and rear camber link installed on 17 IS350. When I got home after picking up the vehicle, I reversed into the driveway and there is a single knock/pop sound coming from the front. It knocks everytime I reverse while turning. Was wondering if you guys know why this is happening? This never happened before, only started happening when I had those items installed onto the vehicle.
Link to the video of the sound:
Thank you in advance!
Old Feb 6, 2021 | 04:41 PM
swaangin's Avatar
swaangin
I get little ones from my RSR springs.. yours are loud af lol
Old Feb 6, 2021 | 05:05 PM
Chunkyyy's Avatar
Chunkyyy
6th Gear
oh haha... is this normal? This is my first time having a lower car. I thought something is about to fly out.
Old Feb 6, 2021 | 05:10 PM
swaangin's Avatar
swaangin
Honestly bro, I don't think that's normal. How often does that happen? I feel like the person who installed em probably didn't assemble it properly, maybe it needs to be readjusted.. you're not rubbing either right?
Yours sounds like you're hitting something with your car, it's way too loud, you have to take it back and re-install
Old Feb 7, 2021 | 09:18 AM
Sasnuke's Avatar
Sasnuke
Since you just had the work done and you can consistently make the noise, I suggest taking it back tot he installer for them to check it.
Duplicate the noise for them so they can see how the noise is made to occur and let them take it from there.
Old Feb 8, 2021 | 11:11 PM
Chunkyyy's Avatar
Chunkyyy
6th Gear
Got it, will definitely bring it back. Thank you
Old Feb 9, 2021 | 07:20 AM
JNP1227's Avatar
JNP1227
I had the same noise (not as loud as yours) when i installed my coilovers only in very slow speeds but mine was coming from the rear. If I added passengers in the car the noise went away. I ended up selling the coils before I was able to diagnose what it was.
Old Feb 12, 2021 | 01:43 PM
laobo979's Avatar
laobo979
I would hope that they torque that ball joint to spec if you had the upper one installed. I had my 2nd gen IS350 with coilover and never had that sound or any other car i owned with coilovers setup. Def double check nuts and end links for the sway bars.
Old Feb 12, 2021 | 09:07 PM
Chunkyyy's Avatar
Chunkyyy
6th Gear
It was the ball joint! After it being torqued down, car is driving fine.
BoostWang
Mar 23, 2021 02:30 PM
PSimpso
Dec 5, 2020 12:46 PM
Yarners
Nov 22, 2020 01:29 PM
jusss2is
Nov 20, 2020 06:43 AM
NoHoIS350
Suspension and Brakes
Feb 22, 2010 04:56 PM
