Do NEW Lower Control Arm Bushings require an ALIGNMENT?
Old Jan 15, 2021 | 01:57 PM
LaZeR's Avatar
LaZeR
Question Installing NEW Lower Control Arm Bushings
Hey, for the drivers that got (GS/RC) Lower Control Arm Bushings installed to reduce inner front tire wear, does this ALSO require a 2-wheel or 4-wheel Alignment, &/or did you also get an alignment done at the same time? Thanks!! https://www.megazip.net/zapchasti-dl...0?q=4807524010
EDIT > got a 4-wheel alignment less than 2k miles ago, but heard that newly installing Lower Control Arm Bushings messes it up?
Old Jan 15, 2021 | 02:01 PM
NickCaesar's Avatar
NickCaesar
I installed, went for alignment...alignment shop said car is in spec already, didn’t charge me...so my car didn’t....if ur car is out of alignment or even if it’s been a few years since u got an alignment it doesn’t hurt to get one.
So no you don’t NEED it but you might...
Old Jan 15, 2021 | 02:05 PM
LaZeR's Avatar
LaZeR
Originally Posted by NickCaesar
I installed, went for alignment...alignment shop said car is in spec already, didn’t charge me...so my car didn’t....if ur car is out of alignment or even if it’s been a few years since u got an alignment it doesn’t hurt to get one. So no you don’t NEED it but you might...
Reason being, got a 4-wheel alignment less than 2k miles ago, but thought newly installing Lower Control Arm Bushings messes it up? Will edit this is in d'OP.
Old Jan 15, 2021 | 03:09 PM
NickCaesar's Avatar
NickCaesar
you’ll be fine, it should not alter alignment if you’re in spec right now.
Old Jan 25, 2021 | 11:38 AM
LaZeR's Avatar
LaZeR
Angry UPDATE > Replacing Lower Control Arm Bushings
Lexus of Tampa Bay wants a whopping $390 to replace the OEM lower control arm bushings with the GS/RC parts... Plus they REFUSE to do it if i don't agree to ALSO getting a 4-wheel Alignment for another $150... and this is the LOWEST quote!! lol
Then I called AAA and they don't install customer supplied parts even if they're genuine... This SUX!!
Old Jan 25, 2021 | 01:02 PM
Jazzrock's Avatar
Jazzrock
Lexus of Tampa Bay wants a whopping $390 to replace the OEM lower control arm bushings with the GS/RC parts... PLUS they refuse to do it if i don't agree to ALSO getting a 4-wheel Alignment for another $150.
Call independent shops. It's a quick process. I had an alignment done as well. You could have it checked as you may not need it One hours labor, though it doesn't take that long.
No need to go to the dealer.
Old Jan 25, 2021 | 02:21 PM
bgross88's Avatar
bgross88
Me and my buddy did mine it less than 45 mins, and that was without a lift. It's an extremely simple process Show this video to your mechanic. Shouldn't take more than an hour.
Old Jan 25, 2021 | 04:29 PM
Sasnuke's Avatar
Sasnuke
A fair price would be an hours labor...depending on what the shops hourly rate is...and barring any issues.
Old Jan 25, 2021 | 08:25 PM
LaZeR's Avatar
LaZeR
Question
@ @bgross88 "without a lift" you mean you just jacked up the car and crawled under?
Old Jan 25, 2021 | 09:24 PM
kj07xk's Avatar
kj07xk
Yes, that’s what I did. Took me longer, as it was just myself, but it can be done. Just make sure you’ve got a torque wrench that goes high enough (had to go out to buy one).
Old Jan 26, 2021 | 01:39 AM
bgross88's Avatar
bgross88
Correct...with a low profile jack.
Old Jan 26, 2021 | 12:03 PM
LaZeR's Avatar
LaZeR
Ya, that, or Murphy's Law kicks in & 3000 lbs of steel crush your head.
Old Jan 26, 2021 | 12:08 PM
Sasnuke's Avatar
Sasnuke
I used a jack and two jacks stands.
Lift the subframe from the front middle with the jack and put each jack stand under the frame rails under the front area of the vehicle floor...once you lower the vehicle onto the stands, keep the jack in place...therefore 3 points of contact to ensure there is no head crushing.
I would suggest even blocking the rear wheels before jacking so there is no roll at all.
Old Jan 26, 2021 | 02:30 PM
bgross88's Avatar
bgross88
Cool
This is exactly what I did as well, should have been more clear, but not sure why working on a car without a lift is a big deal?
Old Jan 28, 2021 | 12:12 PM
wthrman2's Avatar
wthrman2
I wonder if the 2021 model year will have the same issue with premature tire wear
