Winter Setup
Old Aug 23, 2020 | 02:25 PM
athanato's Avatar
athanato
I use my old stock RWD 2IS 17" 225 front 245 rear. The old sensors are still on them, TPMS only alerts after 45min of driving. Since the 3IS is AWD the low tread tires are still performing well.
It comes down to how much effort and money you want to place for winter wheels that will always be dirty.
Old Aug 26, 2020 | 10:44 AM
Infiverse's Avatar
Infiverse
Originally Posted by Sasnuke
I hear your concerns about buying used wheels...all my 2IS winter rims are bent, they were like that when I bought them. (I knew that going in)
Through the magic of Road Force Balancing, you'd never know it driving the car though...even on the highway.
I got them dirt cheap, so couldn't go wrong.
The only concern about the wheels you propose is the offset.
On the rear this will be fine, the concern is the front.
The width of the rim isn't the big issue, it's the offset. I'm not sure if 7 inches wide with +38 offset is enough to clear the big caliper.
A stock F Sport front wheel is 18x8 +45...so effectively you shrank the rim width by 1 inch (25mm) but only moved the offset out 7mm.
Ultimately spoke design is the last barrier to clearance...it may still clear with the right spoke design.
If there's any way you can test fit the rim only on a front wheel, that will answer the question.
Otherwise you're good to go with everything else, including tire size.
The tire will be a little taller than stock heights, but it's not crazy tall.
I just bought and tested it on the front. The rim clears the calipers fine but the socket is small that stock.
I think stock is 21mm and the aftermarket rims fit only 19mm...
Is it possible to buy a 19mm lug nut set or do i have to refund the rims?
Old Aug 26, 2020 | 01:55 PM
Sasnuke's Avatar
Sasnuke
Usually the aftermarket wheels use an acorn style nut, which is completely different to your OEM nuts (shank style aka flange style)...so your OEM nuts are of no use on those wheels.
Just get a set of aftermarket nuts in 19mm...just be sure to put something in the trunk that you can remove them with in the event you need to take a wheel off when you're not at home.
Simplest thing is a 19mm socket (if that's the size you end up with) and one of those collapsible breaker bars. Like this: https://www.clublexus.com/forums/is-...l#post10877079
Old Aug 26, 2020 | 08:26 PM
Infiverse's Avatar
Infiverse
Would any 19mm acorn lug nut fit? What is the thread size and also thickness of the rotor screw?
Would downsizing the lug nut size compromise the safety of wheel/rim? Im guessing no as long as they are torqued to factory spec.
Old Aug 26, 2020 | 10:04 PM
kj07xk's Avatar
kj07xk
Thread size 12mm x 1.50, same as most Lexus/Toyota cars (fits my Jag too).
Old Aug 28, 2020 | 06:27 AM
Sasnuke's Avatar
Sasnuke
As kj07xk stated above, the thread is M12 x 1.5.
The rim supplier should be able to offer an Installation Kit...which will basically consist of all the lug nuts and hub rings for the rims.
The center bore of the rim is likely larger than the Lexus hub.
The Lexus hub is 60.1mm...most likely the rim center bore is 73mm...so you will need a hub ring that fills that gap.
If they don't offer an Installation Kit, then inquire with the shop that is doing the mounting and balancing, they will be able to get you what you need.
Old Sep 1, 2020 | 12:37 PM
Infiverse's Avatar
Infiverse
On the aftermarket rim box it says Hub Bore: 60.1 mm. So looks like im good.
What is the smallest size lugnut that will fit on the lexus threads?
Old Sep 1, 2020 | 04:24 PM
Sasnuke's Avatar
Sasnuke
If the bore is 60.1mm, then they are Direct Fit...which is good, no monkeying around with hub rings.
I would recommend 19mm nuts unless you can't physically fit the socket in the hole.
I'm not sure the smallest size nut you can use, but I wouldn't go smaller than 17mm.
Old Sep 10, 2020 | 10:32 AM
Infiverse's Avatar
Infiverse
Came back from universal auto techs and they quoted me 425 for mounting/balancing tires and programming/installing tpms sensors. Does that seem fair?
Also trying to find replica lexus rims so i dont need to worry about another set of lugnuts..
Old Sep 10, 2020 | 11:12 AM
Sasnuke's Avatar
Sasnuke
The bulk of the cost should be the sensors.
Mounting/balancing and programming is probably around $100.
Do you know if it was OEM sensors? The aftermarket ones will likely not show the pressure on the dash, or consistently show it.
They will only trigger the warning light when the pressure is low.
I haven't priced out sensors recently, but the price seems in the realm of reasonable.
Old Sep 10, 2020 | 11:30 AM
Infiverse's Avatar
Infiverse
Im not sure. I will probably have to ask dominic again if the sensors are OEM.
Old Sep 12, 2020 | 08:54 PM
Infiverse's Avatar
Infiverse
Do you have the part number for the oem tpms sensor? im considering buying them myself
Also the 19mm lug nut fits fine but the socket has only 1mm of clearance from the rim. I noticed on stock f sport, the 21mm lug nut has 5mm+ of clearance from the socket and rim.
Will this lead to potential rubbing/corrosion on the rim in the future?
Old Sep 16, 2020 | 12:08 PM
Sasnuke's Avatar
Sasnuke
The part number is 42607-30060.
They are made by Pacific Industries and the marking on them for our vehicles is PMV-C010.
If you're worried about the rim being damaged by the socket, look for a socket with a thinner wall. If you are not using an impact gun on the socket, then you can use a chrome socket, or they even have ones with plastic around the outside for just this reason.
newToIs250
Sep 11, 2015 05:15 PM
ExtrmeLex
Dec 16, 2012 09:07 AM
nshih
Dec 7, 2012 01:07 PM
Ach1976
Jan 31, 2012 09:37 AM
VitB6
Oct 13, 2006 09:25 AM
