Blizzak fitment possible?
Old Dec 6, 2012 | 11:53 PM
nshih's Avatar
nshih
Default Blizzak fitment possible?
With the winter season coming up, I'm looking to get a good set of winter tires. Will these fit my IS350? My summer wheels are: 225/40/18 Front 255/40/18 Rear
http://seattle.craigslist.org/oly/pts/3449226857.html
Old Dec 7, 2012 | 12:03 AM
Snyperifle's Avatar
Snyperifle
Well, those are 17 inch tires so, no it won't fit your 18 inch rims lol
Old Dec 7, 2012 | 07:01 AM
embolism's Avatar
embolism
those tires come with their own 17 inch rims wheels so you can run them if they fit. You are more concerned about the lugnut pattern and the the fact that the profile is 60. IMO, that's a bit too high. You are currently at 40 with your 18's. Dropping down to 17's gives you half an inch in sidewall all around but 60 may be too thick. Your car would look like a 4x4 even without any gap.
I run your summer setup but then run 225/45/17 in the winter on all 4 corners so I can rotate them if I need to.
Old Dec 7, 2012 | 11:10 AM
nshih's Avatar
nshih
@Snyperifle: OK I'm not that big of a noob. haha
@embolism: So you can safely go down to 17s and not throw off the speedometer? I'm actually wondering more about fitment concerns. I'm in the market for snow tires with their own rims. If I just match up the bolt pattern (which I gather for our cars is 5 x 114) then is that sufficient?
Old Dec 7, 2012 | 12:02 PM
Snyperifle's Avatar
Snyperifle
Oh I thought you gave your current tire specs because you were thinking of swapping them over lol.
I'm pretty sure those rims+tires will fit
Old Dec 7, 2012 | 12:25 PM
laobo979's Avatar
laobo979
First off bolt pattern have to be the same. Consider the width of the wheel compared to your stock. Then the hub centric if there the same mm. Then if it will clear is350 caliper other wise waste of money.
Old Dec 7, 2012 | 01:04 PM
embolism's Avatar
embolism
oh yeah forgot about that. The front 350 caliper is a big mother so it's got to clear it. It's one of the reasons why I just went for some 250 OEM rims off CL when I was prepping for winter. I dropped down to 17's but then got a higher profile tire 45, so the overall wheel diameter stayed about the same. That's why I think 60 will be too much.
As for the speedometer, overall diameter (rim plus tire) is what needs to be the same. Check out the calculators they have at tire rack or similar places to see what different combo's will get you wrt overall wheel diameter compared to your summer specs. As long as you are not off by more than 3% then you are ok. Even if it's a bit more, it might mean a difference of +/- 5mph on your speedo... it's not like it'll matter much driving in the winter...
Old Dec 7, 2012 | 01:07 PM
reyoasian's Avatar
reyoasian
1. Whether tire size is good or not depends on diameter. You have to use a tire size calculator and rule of thumb is within 3% of difference
2. In this specific case no, 17" will not fit your IS350
Aeromotive
Jun 16, 2020 05:49 PM
1blackdog
Suspension and Brakes
Jul 15, 2018 06:36 PM
ExtrmeLex
Dec 16, 2012 09:07 AM
rena
Oct 20, 2012 10:03 PM
kaslead
Oct 31, 2006 08:40 PM
