replace fuse for black navigation display?
Old Aug 1, 2020 | 08:48 AM
dougbetts's Avatar
dougbetts
Default replace fuse for black navigation display?
Hi - my navigation display went black when my battery died, and now it won't turn back on. I've tried resetting by holding down the audio power button, but no luck. Any other advice? I'd like to check the fuse but can't figure out which fuse to check, is there a map of the fuse boxes online somewhere? Thank you.
Old Aug 1, 2020 | 10:22 AM
dojoman's Avatar
dojoman
Wow suddenly lots of people with same issue what yr is your car? Mine is first yr model hopefully won’t have this same problem. Hate to spend $2k just for this crappy system.
Old Aug 1, 2020 | 10:54 AM
dougbetts's Avatar
dougbetts
2014 is350...
Old Aug 1, 2020 | 11:24 AM
dojoman's Avatar
dojoman
Did you unplugged battery for 10 min and see if it comes back on?
Old Aug 1, 2020 | 11:33 AM
dougbetts's Avatar
dougbetts
I had the battery replaced. It went black when the old battery died, then when I jump started the car (with the old battery) and everything else came back to life, the screen was black (no back up camera, no nav display, etc.) I had the battery replaced with a new one, and everything else works, but the screen remained black. So in effect, yes the battery was unplugged and put back in again. Do I need to do that again?
Old Aug 1, 2020 | 11:34 AM
dougbetts's Avatar
dougbetts
Some earlier posts suggested checking the fuse, but I can't decode the fuse box guide so I have no idea which fuse to check.
Old Aug 2, 2020 | 09:24 AM
Sasnuke's Avatar
Sasnuke
Try disconnecting the battery again for a minimum of 10 minutes.
If that doesn't work, then you are looking at a radio head unit.
The screen is fused through the radio, so the screen itself doesn't have a fuse.
Unfortunately as your vehicle is a 2014, the likely cause is the radio head unit.
Old Aug 2, 2020 | 09:33 AM
dojoman's Avatar
dojoman
Sorry to hijack your thread but I’m curious if radio HU failed can I hook up after market CarPlay unit like 4x4 android screen it still won’t work right? Even though climate control works I won’t have any joystick control to after market system. If mine breaks I don’t think I want to spend $2k just for crappy system I rarely use.
Old Aug 2, 2020 | 10:32 AM
dougbetts's Avatar
dougbetts
Dojoman and Sasnuke, THANKS! I disconnected the battery, waited a while, and reconnected - that solved the problem. Much appreciated!
Old Aug 2, 2020 | 12:24 PM
dojoman's Avatar
dojoman
Glad it works out. Sometime just a reset to the system brings it back to life. I wonder how many people didn’t do this and end up getting a new headunit.
Old Jan 12, 2023 | 12:36 PM
Ashis350's Avatar
Ashis350
1st Gear
Default I'm having the same problem now on my 2014 is350😒
Patrickleo
Apr 7, 2017 12:02 PM
Taidaisher
Nov 15, 2014 04:34 PM
njsges
Oct 7, 2008 09:50 AM
phattbam
Nov 10, 2007 04:41 PM
