Transmission issue?
Old Jun 12, 2020 | 01:35 PM
mario350's Avatar
mario350
Default Transmission issue?
FullSizeRender.mov
Hi all,
I’ve been having intermittent issues lately when driving my 2014 Lexus IS350 RWD, I noticed that when I put my car into drive the slip indicator will starting blinking as I stepped on the gas and the rpms would not move what so ever, also I sometimes get a message to Check ABS and Check BSM, I have attached photos and video of the issue, the photos were taken all within a minute as the message popped up it went away almost immediately, and the video was later that day when I started having the slip indicator issue and no rpm movement. However, I do not believe that it is a transmission problem as on other days it drives fine and the gears change as they normally would, I am just assuming it might be. Has anyone else had this problem, if so please let me know, I am currently about to check all the wiring to see if they’re all connected good.
Old Jun 13, 2020 | 08:27 AM
Sasnuke's Avatar
Sasnuke
My guess is that it is not the tranny either...which is good news.
If I had to guess, I'd say that you are having an issue with one of the ABS sensors, and that is causing the ABS and BSM malfunctions...which is also why the RPM's may not be moving, the computer may be thinking you are in some kind of slip situation.
Has the vehicle been is for any repairs lately or in an accident?
If you have access to a Techstream, when the warning lights are on that is the perfect time to check for the codes...then you should know exactly where the malfunction is.
Old Jun 13, 2020 | 12:20 PM
mario350's Avatar
mario350
No, I haven’t had any repairs or any accident lately, I’m thinking in just taking it to the shop this coming week and leaving it there for the week to see if they are able to replicate the issue, hopefully they are able to figure what’s wrong.
Old Jun 13, 2020 | 12:23 PM
Sasnuke's Avatar
Sasnuke
Sometimes the codes may even be stored in the History section of the ECU, so they may still be able to see the codes even if the lights aren't on.
Unfortunately without the codes it's pretty much a crap shoot as to what the malfunctioning part is...I think it's safe to say the part will be in the ABS system, but that still leaves you several possibilities.
andyN
Apr 22, 2024 07:30 AM
Bimmer32
LX - 3rd Gen (2008-2021)
19
Nov 27, 2022 04:30 PM
Juan75211
Jan 26, 2017 05:34 PM
phiberglas
Mar 31, 2010 08:51 PM
Jimbo2828
Oct 24, 2007 10:22 AM
