Unlocking and locking door delay on the handle
Old Dec 28, 2021 | 03:42 PM
cal78's Avatar
cal78
10th Gear
Originally Posted by Sasnuke
Without knowing what the code is you'll likely never be able to fix it...at least the code will give you a starting point as to what to look at.
Every error has a related code, that way no matter where in the world the car is the code will always be the same for the same error.
So if your car has a B1234 and my car has a B1234, then it's the same error.
For them to tell you ECU Decentralization (or whatever it is in French) isn't a code nor does it help at all.
hey hey
i bought techstream ... so i have a B1249 so if i m checking in toyota we have a link with door ( DTC)
i m lost
Old Dec 28, 2021 | 04:33 PM
Sasnuke's Avatar
Sasnuke
Originally Posted by cal78
hey hey
i m lost
Apparently we don't have that code (B1249) here in North America for Lexus...but we do have it for Toyota.
Since we don't get the IS300h here, I can only assume you have the "Double Locking ECU" in your vehicle.
As a simple first step, check the two fuses that are associated with the ECU...DOOR DB/L and ECU-DCC NO.2...once again I assume you have these fuses in your car.
Old Dec 28, 2021 | 05:20 PM
cal78's Avatar
cal78
10th Gear
YES i have the same link in google and in french also. I will see...
https://www.tochrfr.com/2328/arr_t_d...ge_b1249_.html
Old Nov 23, 2023 | 02:14 PM
cal78's Avatar
cal78
10th Gear
I m coming back... No improvement
RaysIS350
Oct 11, 2021 02:04 PM
tonyzebra
15
Aug 22, 2012 04:40 PM
Justinizme
Jan 19, 2012 07:54 PM
jadeaudio
RX - 1st Gen (1999-2003)
Oct 22, 2009 07:09 AM
LS_4Will
Nov 13, 2004 09:41 PM
